Old 11-25-2006, 08:21   #1 (permalink)
Member: 372599
Thanks Meter: 41
N70 , Chargint but not coming ON
hi guys..
I have one N70 which was water damage.. before... but after cleaning now the phone is charging but not switching ON.... can anybody please tell me how can i fix this problem.. thanks a lot
Old 11-25-2006, 12:36   #2 (permalink)
baraka42's Avatar
Member: 14578
Thanks Meter: 829
Originally Posted by bakhshalvi007 View Post
hi guys..
have you check on -off switch ?
try this,
The Following User Says Thank You to baraka42 For This Useful Post:
Old 11-25-2006, 12:58   #3 (permalink)
Member: 125111
Thanks Meter: 25
see schematic diagram... change the display i.c 100% working
Old 11-25-2006, 13:25   #4 (permalink)
Member: 97043
Thanks Meter: 29
cool answer nice solution.
Old 11-25-2006, 17:51   #5 (permalink)
efrcom's Avatar
Member: 128481
Thanks Meter: 349
hi guys..
http:///vbb/showth...68#post2106468
look at these schematics. i am sure that it can be helpfull.
good luck
yours respectfully
efrcom_ Lutfi Cagil
Old 11-26-2006, 00:02   #6 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
if all previous suggestions doesn't works then try to review the RETU IC by resoldering it & if not works then replace it ...
Old 11-26-2006, 03:07   #7 (permalink)
abu osama's Avatar
Member: 103786
Thanks Meter: 81
change the display i.c 100% working 100%100%100%100%100%100%100%100%100%100%100%100%10 0%100%100%100%100%100%100%100%100%100%100%100%100% 100%100%100%100%100%100%100%100%100%100%100%100%10 0%100%100%100%100%100%100%
Old 11-26-2006, 06:16   #8 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
Lightbulb
hey man, hi is saying that "the phone doesn't power on" not "the phone is not displaying" , there is nothing to do with the display IC.
Old 11-26-2006, 06:21   #9 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
Lightbulb
as i mentioned i think if it's not the power switch then it's RETU IC fault .
Old 11-26-2006, 06:28   #10 (permalink)
rana_sab's Avatar
Member: 62911
Thanks Meter: 156
Smile
hi guys..
see the attachmint this is the 100% solution for your problem
Old 11-26-2006, 07:40   #11 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
Exclamation
how could you said that !!!!!!!!!!!!!!!!!
trace the power on key track in the schematic diagram & find out where it goes, see in the picture, it goes directly to the RETU IC, there is no other ICs or filters on its way but the R4406
with the GND,so how come you said that !!!!!!!!!!!!
The Following User Says Thank You to mobilagy For This Useful Post:
Old 12-04-2006, 04:43   #12 (permalink)
mobilagy's Avatar
Member: 217479
Thanks Meter: 267
Lightbulb
well, i have checked the measurement between the power switch & the point mentioned in your attached picture & i realized that the two points has a connectivity with resistance but i don't know how due to the schematic diagram that i mentioned !!!
may be it differ for some boards design.
Old 12-06-2006, 11:09   #13 (permalink)
malek45's Avatar
Member: 32529
Thanks Meter: 23
for n70 the power switch filter has been integreated in LCD IC if u change it it work perfectly
i repaired a new one with a same problem
if u want to repaire it .....
u must test
Old 12-07-2006, 10:31   #14 (permalink)
Member: 23612
Thanks Meter: 15
anyone have solution to N70 offline problem without changing sim ic and i am looking for N70 diagram thanks
Old 12-07-2006, 16:21   #15 (permalink)
Member: 139043
Thanks Meter: 27
Do we remove the glass ic and from the 2nd point we link a wire to the power switch? And do we link to the left or right hand side of the power switch???
6111 charging but not comes on solution here.. chohansahib Nokia Hardware & Hardware Repair 0 02-17-2010 01:25
n70. charge, but not switch on escorpiao Nokia Hardware & Hardware Repair 9 10-11-2008 10:36
N70, Chargint but now swithing ON bakhshalvi007 Nokia Hardware & Hardware Repair 1 11-26-2006 12:11
Sony Ericsson p910i charge but not coming on Ggnets Sony Ericsson Hardware Repair 1 09-09-2005 19:19
??? Ericsson Not Come On, But Service Light Steady Glow dannyogolo Old Ericsson Phones & Sony Phones 1 03-05-2003 17:48
Page generated in 0.43998 seconds with 9 queries
