Old 08-22-2008, 11:32   #1 (permalink)
Member: 771665
Sonork: sonera
Thanks Meter: 8
Red face n70 cmt error
nokia n70 cmt error while flashing help guru
Old 08-22-2008, 11:40   #2 (permalink)
cool_nash23's Avatar
Member: 841203
Thanks Meter: 44
n70
try to chang the resistor on your cable and flash it again
Old 08-22-2008, 12:09   #3 (permalink)
BACK's Avatar
Member: 304574
Sonork: 100.1593675
Thanks Meter: 72
change the cable ues 7 pin cable then flash
Old 08-22-2008, 18:04   #4 (permalink)
Member: 675717
Thanks Meter: 125
Use 7 pins modifyed cable.
Old 08-23-2008, 06:42   #5 (permalink)
Member: 771665
Sonork: sonera
Thanks Meter: 8
Unhappy n70 cmt error
sir i'm using jaf modify cable already
Old 08-23-2008, 07:40   #6 (permalink)
Member: 465901
Thanks Meter: 45
first of all check the supplies of the cmt flash you can check it with jaff just go to the self test in service and run-all you will see where your problem exists
your problem lies in the flash ic or in the rap3G ic reheat the flash ic or the rap3G ic.
Old 08-23-2008, 07:44   #7 (permalink)
Member: 270413
Thanks Meter: 15
hi bro
magic solition remove on/off button after pro (hwk or ufs) tested
Old 08-23-2008, 07:48   #8 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
check your APE and smps supply it should be 1.8v or check your sram
Old 08-23-2008, 07:50   #9 (permalink)
Cheater -Don't Deal with him-
Member: 677681
Sonork: 100.1590886
Thanks Meter: 232
post logs here ...............
Old 08-23-2008, 08:46   #10 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
yes post log here so ve can help u in best.....
Old 08-23-2008, 11:12   #11 (permalink)
nisamknr2@yahoo's Avatar
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
select manual flash file.after make flash
Old 04-04-2009, 19:41   #12 (permalink)
chandio_180's Avatar
Member: 602248
Thanks Meter: 69
nokia white hang .
here is log:-
ooting phone...
APE Boot Data:
Asic ID: 17100701
Asic Mode ID: 00
Asic Public ID: 5B92AC3887D291043E09DDCF9F1BD01016069C2C
HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
ROM ID: AB5E4ADB27A06946
CMT Boot Data:
Asic ID: 000000010000022600010006000C192101002200
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 18F000054B0E595130203D4820F967F4387690D1
HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000
ROM ID: F28A211FCEA7B19D
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv2_2nd.fg
Loader version: 01.15.00 -> Revision: 0000
Patching CMT boot step2...
Error loading cmt boot...
plz hlp me .........
thanks in Advnce
Old 04-05-2009, 05:30   #13 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
ape is ok,cmt boot error, have u checked by changing cable?if ok then handset may be waterdamage. clean board, or heat upp
Old 04-05-2009, 07:40   #14 (permalink)
Member: 602248
Thanks Meter: 69
thanks 4 rply
dear i changed cable but same prob, board is not waterdamage
its new ........
i remove ape and make jumpers.....
now what i have 2 do
Old 04-05-2009, 09:08   #15 (permalink)
gokul2005's Avatar
Member: 169384
Thanks Meter: 110
its maybe nand flash(samsung) ic complaint
n70 CMT error lovermobile Nokia Hardware & Hardware Repair 4 09-26-2009 05:17
N70 cmt error erick_ponsel88 Nokia Hardware & Hardware Repair 1 04-10-2009 13:57
N70 cmt error wijayaponsel Nokia Hardware & Hardware Repair 5 12-30-2008 20:36
sos n70 cmt error plz moon77 Nokia Base Band 5 ( BB-5 ) 2 06-15-2008 18:36
Page generated in 0.21996 seconds with 9 queries
