06-09-2009, 14:56 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: punjab
Member: 357914 Status: Offline Thanks Meter: 71 | n70 dead phone info:: :MCU SW : V 05wk07v47 30-01-07 RM-84 (c) Nokia. APE Core: V 5.0705.3.0.1 30-01-07 RM-84 (C)Nokia APE Var : V 5.0705.3.0.1-32.01 30-01-07 RM-84 (c)Nokia Prd.Code: 0539276 Bpr.Code: 0536420 Prod.Sn : CJJ049512 HW Vers : 7003 APE HW : 256 APE Adsp: 16054 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 150a160f DSP Vers: rolf_05wk07v29p1 LCD Type: 0 IMEI : 356********0-9 SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland |
The Following User Says Thank You to amardeepsahi For This Useful Post: |
06-09-2009, 15:42 | #4 (permalink) |
No Life Poster Join Date: Sep 2008 Location: BANGLADESH
Member: 852543 Status: Offline Thanks Meter: 2,338 | nokia coad * # U ** D # - status of the bypasses query: Input without ** D queries all services and bypasses Bypass in the speaking and/or fax box: Number in bypass procedure with D=11 and/or 13 enter Goal call number (e.g. D2-Netz: +49,172 xxx) and Handynummer without preselection (if necessary 172 replaces) enter. Tap: During switched on rufumleitung "with occupied" being able "to reject" calls by one the red key during "to ring" presses. The caller is then passed on to the goal call number of the occupying bypass (e.g. mailbox). Type for waiting period during rufumleitung 61: ** 61 * [ goal call number ] * 11 * [ time in sec. (5 to 30) ] # This also partly goes with 6600 via menu: Attitudes - rufumleitungen -... Knock/stops/parks/faults Knocks is signaling a secondary call during a current discussion * 43 # - switch on # 43 # - switch off * # 43 # - status query This also partly goes with 6600 via menu: Attitudes - calls - knocking... 0 < sends > - reject while the discussion a knocking 1 < send > - discussion terminate, knocking discussion accept certain discussion (y) terminate 1 (y) < send > 2 < sends > - discussion park, knocking discussion accept certain discussion and new discussion leads 2 parks (y) < sends > 0 < sends > - caller the busy condition signal This also partly goes with 6600 via menus existing during the discussion. ---------------------------------------------------- Call barrier Possible only if bypass of the service code is switched off. Check code (S): S=33 all outgoing transmissions S=331 outgoing abroad S=332 outgoing abroad except home S=35 all arriving transmissions S=351 all arriving abroad Special check codes (s) delete: Switch off only in connection with the procedure S=330 check code status outgoing & arriving transmissions switch off S=333 check code status outgoing transmissions switch off S=353 check code status arriving transmissions switch off Service code (D): Not all nets support all services D=10 language and fax (all calls) D=11 only language D=12 all data (speed/minutes) D=13 only fax D=14 DATEX j (active?) D=15 teletex (active?) D=16 only SMS D=18 all data except SMS D=19 all services except SMS D=20 all services D=21 all asynchronous services D=22 all synchronous services D=23 3.1 kHz GSM of language services D=24 all synchronous POINT ton of POINT DATA inclusive. PADs D=25 only data (all asynchronous POINT ton of POINT DATA inclusive. PADs) D=26 data packet exchange links incl. PADs D=27 services thru PADs D=29 12 Kbps digital link * S * [Passwort] * D # - einschalten der Anruf-Sperre # S * [Passwort] * D # - ausschalten der Anruf-Sperre *# S # - Status der Anruf-Sperre abfragen Passwort für Handy Sperre ändern: ** 03 ** [altes Passwort] * [neues Passwort] * [neues Passwort wiederholen] # ** 03 * 330 *[altes Passwort] * [neues Passwort] * [neues Passwort wiederholen] # Dies geht beim 6600 auch teilweise via Menü: Einstellungen - Anrufsperre ... ------------------------------------------------------------ ---- PIN ändern ** 04 * [alte PIN] * [neue PIN] * [neue PIN wiederholen] # ** 042 * [alte PIN 2] * [neue PIN 2] * [neue PIN 2 wiederholen] # PIN entsperren: ** 05 * [PUK] * [neue PIN] * [neue PIN wiederholen] # PIN 2 entsperren: ** 052 * [PUK2] * [neue PIN 2] * [neue PIN 2 wiederholen] # Dies geht beim 6600 auch teilweise via Menü: Einstellungen - Sicherheit - Telefon und SIM ----------------------------------------------------- Diverse Codes Die folgenden Codes klappen nur in einigen (wenigen) Netzen/Netzbetreibern ... leider z.B. nicht im Vodafone D2 Netz (in Deutschland): *#100# - Eigene Nummer (Own Number) *#101# - HLR Nummer *#102# - Switch Nummer *#103# - Zeit im Netz (Network Time) *#104# - Anrufbeantworter Nummer (Voice mailbox number) *#105# - Switch number *#147# - Letzter Anrufer (Last Caller) #646# - Minutes Used: (646 spells 'MIN') *#1345# or *174# - Vodafone Prepaid balance *78 - Do not disturb - nur in Nord America in GSM und CDMA Netzen möglich *79 - Cancel (s.o.) --------------------------------------------------- CHECK SIM-LOCK Note - If you bought your Nokia on UK Vodafone or UK Cellnet you do not need to check this because they both transmit on GSM900, and they don't lock the phones. However if you bought your phone on UK Orange or UK One2one your phone may be blocked. The reason is that they both transmitt on GSM1800. To make a call on GSM1800 you need what is known as a "Dual band" phone. A dual band phone is able to transmit on both GSM900 and GSM1800, so they lock the phones so you can't use it with any other network simcard. If you find that your phone is locked you can try different software to unlock it. (we havn't found one that works yet), or you can ask your service provider who will gladly exchange the 10 digit code for about £35. This is how to check the status of the 4 different locks. Aslo don't try entering the wrong number, because after 3 times it will block the phone for good. There are 4 different locks on your Nokia phone. COUNTRY-LOCK NETWORK-LOCK PROVIDER-LOCK SIMCARD-LOCK The code to read out the sim-lock status of your phone is #PW+(MASTERCODE)+(Y)# # = DOUBLE-CROSS W = PRESS "*" THREE TIMES P = PRESS "*" FOUR TIMES + = PRESS "*" TWO TIMES MASTERCODE = 1234567890 Y = NUMBER 1 TO ------------------------------------- THE JAMES BOND TRICK If you short-circuit theleft middle and right pins on the bottom of the phone with all connections touching each other, the Nokia software hangs! The profile "Headset" will be activated. Before you do this just activate the "Automatic Answer" in the headset profile and set the ringing volume to "Mute". Now you can use your phone for checking out what people are talking about in a room. Just place it under a table in a room and call it. The phone receives the call without ringing and you can listen to what people are saying. ----------------------------------------------------- Clock Stopping To check weather your SIM Card supports clock stopping type- *#746025625# (*#SIM0CLOCK#) --------------------------------------------- To enter the service menu type- *#92702689# (*#WAR0ANTY#) Serial number (IMEI) Production date (MM/YY) Purchase date (MM/YY) You can only enter the date once. Date of last repair (0000=No repair) Transfer user data to another Nokia phone via Infra-Red NOKIA 6110/6120/6130/6150/6190 IMEI number: * # 0 6 # Software version: * # 0 0 0 0 # Simlock info: * # 9 2 7 0 2 6 8 9 # Enhanced Full Rate: * 3 3 7 0 # [ # 3 3 7 0 # off] Half Rate: * 4 7 2 0 # NOKIA 3110 IMEI number: * # 0 6 # Software version: * # 0 0 0 0 # or * # 9 9 9 9 # or * # 3 1 1 0 # Simlock info: * # 9 2 7 0 2 6 8 9 # NOKIA 3330 *#06# This will show your warranty details *#92702689# *3370# Basically increases the quality of calling sound, but decreases battery length. #3370# Deactivates the above *#0000# Shows your software version *#746025625#This shows if your phone will allow sim clock stoppage *4370# Half Rate Codec activation. It will automatically restart #4370# Half Rate Codec deactivation. It will automatically restart Restore Factory Settings To do this simply use this code *#7780# Manufacturer Info Date of Manufacturing *#3283# *3001#12345# (TDMA phones only) This will put your phone into programming mode, and you'll be presented with the programming menu. 2) Select "NAM1" 3) Select "PSID/RSID" 4) Select "P/RSID 1" Note: Any of the P/RSIDs will work 5) Select "System Type" and set it to Private 6) Select "PSID/RSID" and set it to 1 7) Select "Connected System ID" Note: Enter your System ID for Cantel, which is 16401 or 16423. If you don't know yours, ask your local dealer for it. Select "Alpha Tag" 9) Enter a new tag, then press OK 10) Select "Operator Code (SOC)" and set it to 2050 11) Select "Country Code" and set it to 302 for Canada, and 310 for the US. 12) Power down the phone and power it back on again ISDN Code To check the ISDN number on your Nokia use this code *#92772689# |
The Following 3 Users Say Thank You to masum_sohel For This Useful Post: |
06-12-2009, 15:39 | #5 (permalink) |
Member: 357914 Status: Offline Thanks Meter: 71 | i do this nd now phone showing nokia with ufsx. but not power on.i also change lcd ic.but problem same. MCU SW : V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. APE Core: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia APE Var : V 5.0737.3.0.1-12.01 13-09-07 RM-84 (c)Nokia. Prd.Code: 0539276 Bpr.Code: 0536420 Prod.Sn : CJJ049512 HW Vers : 7003 APE HW : 256 APE Adsp: 16054 EM RETU : 32 EM TAHVO: 53 RFIC Ver: 150a160f DSP Vers: rolf_05wk07v29p1 LCD Type: 2727964 IMEI : 356**********0-9 SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland Init Local Mode Ok, Time: 00:26 Init Test Mode Ok, Time: 00:00 Init Normal Mode Ok, Time: 00:00 |
07-21-2009, 13:29 | #11 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Tunisia
Member: 88177 Status: Offline Sonork: 1594092 Thanks Meter: 71 | please explaine more!! i have the same porblem, but mine not charging and with jaf it work fine!!!! thanks Last edited by m_choko; 07-21-2009 at 13:36. |
N70 Dead-flashing In Jaf And Mtbox Ok-but Still In Dead | zone2 | Nokia Hardware & Hardware Repair | 1 | 11-16-2007 20:23 |
N70 Dead After Flash | Copernico | MT-BOX | 4 | 04-13-2006 14:52 |
N70 dead after flashing | simply-cy | Nokia Base Band 5 ( BB-5 ) | 0 | 12-28-2005 12:04 |
