04-30-2008, 20:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::n70 fake charging (no charging volts)::.. ..::HUM::.. |
05-01-2008, 19:54 | #7 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | the set is working ok,the only thing is that when i connect charger some times it show full battery indication sometime continue charging,the battery timing also ok,the only thing with customer is that y it not show full battery indication, otherwise set works ok. ..::HUM::.. |
11-30-2008, 17:00 | #12 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | firstly change 'tahvo'.mostly problem will be solve.if problem same then change red marked diode shown in picture.i repaired successfully. try it and post reply. wbr shoeb |
The Following 3 Users Say Thank You to shuaib_kashish For This Useful Post: |
..::n70 both charging pads are short with each other & no charge indication::.. | HUM | Nokia Hardware & Hardware Repair | 20 | 03-05-2015 11:59 |
Nokia 6310 - No Buzzer, No Vibrator, No charging | repairs online | Nokia Hardware & Hardware Repair | 1 | 08-15-2007 08:59 |
K300 no earphone,No mic & No charging | RAMSUL | Sony Ericsson Hardware Repair | 13 | 10-07-2006 08:21 |
5210 charging ..no charging help | pabloo81 | Nokia Hardware & Hardware Repair | 1 | 04-21-2005 17:06 |
T28s No Charge, No Network, Dark Displey and no Light | Sultan | Sony Ericsson Hardware Repair | 2 | 05-15-2002 00:57 |
