Old 08-06-2009, 16:30   #1 (permalink)
Member: 507911
Thanks Meter: 22
Question n70 first in the world like this i think !
can anyone give me advise what should i do next , i have nokia n70 canot power on event the respon on power suply exist but like dead software , try to charging no respon at all , but whe i put that n70 to box flashing sho lokal mode and can boot well on normal mode too , try selft test all pased ok , but if itry to use baterei or power suplay canot on !
i change retu , reball ic flash , full flashing , change the lcd emif , smps , the problem still exist ( not work ) !
what next ??????.................
Old 08-06-2009, 16:45   #2 (permalink)
Crazy Poster
Member: 506016
Thanks Meter: 2
you think first in the world ! no no and no , it is old slution , very old .
Old 08-06-2009, 19:02   #3 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
well just change display ic right hand side one should be ok , tested on many phones
The Following User Says Thank You to ..::Mr999::.. For This Useful Post:
Old 08-06-2009, 19:08   #4 (permalink)
Member: 389002
Thanks Meter: 82
yes this is the solution, just replace new one... thats old problem use search ....ask first in this forum before you post those tittle
Old 08-06-2009, 19:11   #5 (permalink)
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
bro hardware is not easy we can say and some time little problems make us crazy .... and this solution i learn from my master and yes tested on many n70 and n72 phones , local mode ok , flash oki , info oki .
but no power on manually
this is working sure
Old 08-06-2009, 19:23   #6 (permalink)
himanshu taldar's Avatar
Member: 422762
Sonork: 100.1593904
Thanks Meter: 973
The Following User Says Thank You to himanshu taldar For This Useful Post:
Old 08-07-2009, 05:48   #7 (permalink)
Member: 507911
Thanks Meter: 22
like i says i already change the lcd emif ( lcd driver two of them ) but not work brother !!!!!!!
but thanks for all atention .... keep going !
whats next ?????????......
Old 08-08-2009, 04:26   #8 (permalink)
Member: 507911
Thanks Meter: 22
up up where is the master !!!!!!!!!!!!!!
Old 08-15-2009, 18:13   #9 (permalink)
Member: 507911
Thanks Meter: 22
problem solved !!!!!!!!!!!
after research view day problem solved by change the smps ic regulator !!>>>>>>>>>>>>>> !
FIRST IN THE WORLD MXKEY 3 IN 1 TOOL...FIRST IN THE WORLD MXKEY 3 IN 1 TOOL... Blac alwi7666 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 46 05-31-2010 14:07
this is new box i wish new support this model unlock first in the world somonahmed Advance-Box 4 02-26-2010 13:57
First in the world solutions by this tiny Thing? Also Raskals BB5 box in stock .:Spitfire:. Main Sales Section 0 10-09-2007 21:26
3 x FIRST IN THE WORLD!!! Check this out!!! ***NsPro v2.0.0 released*** UnlockCellular NSPRO 40 02-22-2007 18:21
Page generated in 0.20440 seconds with 10 queries
