Old 11-12-2007, 13:42   #1 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
n70 flashing error
please help me nokia n70 dead. i connect UFS+hwk tornado3 but flashing time 1st boot & 2nd boot OK& CMT algo boot OK .then using internal vpp &only FLASHING in CMT after 1st boot error no response and no flashing .
Old 11-12-2007, 16:36   #2 (permalink)
Member: 231589
Thumbs down
use mt box or ub box flash with charger conecting
Old 11-13-2007, 07:53   #3 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
i have jaf box & 7 pin cables but same problem any solution
Old 11-13-2007, 09:48   #4 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hi,,,,,, I think your Bluetooth ic is problem so rehot BT ic or flash again if not done then change BT ic if don’t haveBT ic remove BT ic and flashing time disable BT FLASHING…then flash your set I think your problem solved….best off luck
Nokia N70 Flashing Error fusion007 Universalbox 36 11-01-2010 15:22
Page generated in 0.36541 seconds with 8 queries
