Old 04-07-2007, 11:00   #1 (permalink)
Member: 248319
N70 freeze
I have N70 freeze after 2/3 minutes to the power on.
any ideas?
Old 04-07-2007, 11:03   #2 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
Have you tried to format it with *#7370# ?
Bypx
Old 04-07-2007, 11:08   #3 (permalink)
Member: 248319
yes, I format and reflash..
Old 08-20-2007, 17:53   #4 (permalink)
Member: 12724
Thanks Meter: 30
Same problem here,In my case its hardware.working with keypad results freeze.
But I am not sure it is omap - rap3g - cmt or ape
Old 08-20-2007, 18:02   #5 (permalink)
Member: 113853
Thanks Meter: 16
This is hardware prolam
Old 08-20-2007, 20:52   #6 (permalink)
Member: 217853
Thanks Meter: 13
ist chk with software if the problem remains same then check the smps ic voltage accurate 1.4 not less then that.if voltage drops then change smps ic or make jumper ,lots of hanging solutions is available in this site.click the search button .u will find ur solution .best of luck
Old 08-21-2007, 00:00   #7 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
jumper of
- Ape regulater
- smps
GsmJoman
Tc
Old 08-21-2007, 07:58   #8 (permalink)
Member: 12724
Thanks Meter: 30
This phone is not hang /frezee like smps case on white screen.
It freeze time random,some time after a minute some times after an hour some times after some days.
and when it hangs,LCD picture is there.and yes fully formatted and latest flash uploaded before.
Old 08-21-2007, 08:03   #9 (permalink)
Member: 12724
Thanks Meter: 30
I must add this:
No post about this kind of hanging is in forum,I searched two times.
all hangings are white screen hanging.and freeze on start up
but my case is diffrent.it hangs on menus,on standby,.....and random time.
Old 06-02-2008, 10:47   #10 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 44
Originally Posted by .::AkhavanGSM::. View Post
I must add this:
1 year after the post i have the same problem
m8 , did you find the problematic IC ???
did you solve the problem?
Old 06-02-2008, 11:40   #11 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
chk your power switch
Old 06-02-2008, 12:49   #12 (permalink)
Stoyan's Avatar
Member: 14868
Thanks Meter: 44
hehe, this is not a solution man, it is solution for store sellers.
mine phone is freezing after a couple of seconds after work in the menu.
no need to check the switch
Old 06-16-2008, 08:11   #13 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
no need to check the switch........
Old 10-07-2009, 12:05   #14 (permalink)
NAZTY's Avatar
Member: 553264
Thanks Meter: 594
Same problem, N70 starts up normal most of the time, displays full signal, goes into all menu functions....
BUT freezes after a while or when on a call & then switches off & back on again on its own. Tried reheating & complete flashing as well as sl repair & unlock but the phone is still the same.
Flash ic is sealed but i suspect that it may be the cause of the problem.
Has anyone got a 100% solution???
TIA.
REGARDS
NAZTYŽ
"DONT GAIN THE WORLD & LOSE YOUR SOUL.....
.....WISDOM IS BETTER THAN SILVER & GOLD"
Old 04-01-2010, 12:50   #15 (permalink)
Member: 392792
Sonork: lasa_dal
Thanks Meter: 8
same here i got N70 like this all the SW tricks don't work
n70 freeze help me pleeeeeseeeeeee helin Nokia Base Band 5 ( BB-5 ) 5 01-18-2008 00:52
n70 freezing with GPS TomTom5 Rudei GPS devices , Navigators & Maps 18 07-12-2007 20:25
N70 Freezing bakhshalvi007 Nokia Hardware & Hardware Repair 7 07-04-2007 20:32
Nokia N70 FREEZE zhuzh Nokia Hardware & Hardware Repair 3 04-12-2007 20:35
Page generated in 0.29153 seconds with 10 queries
