07-07-2008, 09:46 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Madrid, ES. Age: 41
Member: 51153 Status: Offline Sonork: 100.113241 Thanks Meter: 3,682 | N70 hang only when put Sim card without sim phone work ok, any solution? Hang at Continue using phone in offline mode? then after 10 sec restart. |
The Following User Says Thank You to F@RUK S For This Useful Post: |
07-07-2008, 09:47 | #2 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, do you flash it if not then flash it post your result |
The Following User Says Thank You to jimm07ct For This Useful Post: |
07-07-2008, 21:41 | #10 (permalink) |
Freak Poster Join Date: Dec 2007 Location: Pakistan
Member: 641971 Status: Offline Thanks Meter: 34 | Its Not Software Problem Or Sim Ic Problem Its Hardware Problem I Cant Uplode Image With Trick Becase Gsm Hosting Cant Uplode Any Attechment But I M 100000% Sure Its Hardware Problem So Dont West Ur Time In Software Or Formatting Or Changing Sim Ic Search Here Is Soloution In This Forum |
07-08-2008, 08:57 | #11 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BD/Italy
Member: 324042 Status: Offline Sonork: 100.1578276 Thanks Meter: 3,504 | F@RUKS ................. mybe 100% sim IC problem... change it. |
The Following User Says Thank You to mehedi.h.j For This Useful Post: |
07-08-2008, 09:16 | #12 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: UK Age: 45
Member: 318277 Status: Offline Thanks Meter: 92 | Quote:
First chk Sim IC volages..and Change sim IC ..Done!!! If not OK Flash with the same version u had befor!! Cheers! pls post result! Br | |
07-09-2008, 07:58 | #13 (permalink) |
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, if you try to flash and problem same then change sim ic or make jumper post your result i hope this method can solve your problem Jhon Jimmy |
07-09-2008, 08:27 | #14 (permalink) |
Product Manager Join Date: Sep 2003 Location: Indonesia Age: 45
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,140 | have try it??? flash and change sim card ic???? if still have same problem.... i thing i have solution for u... but please try that soluitons first... regards www.borneoflasher.com |
The Following User Says Thank You to Rizal Arsyad Dini For This Useful Post: |
iphone 3G gets hot when i put sim card | K1n | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 03-14-2010 05:15 |
w580 switch off when i put sim card | Boshko_Alfa | Sony Ericsson Hardware Repair | 4 | 12-18-2009 15:43 |
Nokia 2626 switch off when put sim card | dey mobiles | Nokia Hardware & Hardware Repair | 2 | 12-18-2009 12:57 |
Nokia 6680 When Put Sim Card Hang In Start Phone | Jeffyoh88 | Nokia Hardware & Hardware Repair | 4 | 01-01-2008 11:06 |
w220 hang at motorola logo when insert sim card | siang8788 | Infinity-Box | 4 | 08-04-2007 14:14 |
