N70 LCD EMIF Z4403 line broken 1 Attachment(s) hi... dear Sirs, i have accidentally make the EMIF Z4403 line broken when trying to make it clean from left off lead, before applying new EMIF.... there is suppossed to be 25 dots representing the line Now i have lost dots no 09 and 19, according to the EMIF diagram here... does anyone know how to make jumper for the broken line? i will very gratefull for your help, thanks in advance |
practically its impossible to connect the track to OMAP. |
:( is there any test point left on the board to jumper on? |
Man, just mount the new filters that you were doing & then give it a try & i'm bit sure it will work; there's a lot free pins with these filters & it's which mostly gets off board, just give it a try & you will not regret, i have faced such same problems & was as i told, B.R ... |
i already try mounting the new filters but there were still no good display on LCD.... please anyone who have encounter the same problem give advice thanks mate |
Good work thx for sharing !!!!!!!!!!!!!!!!!!!!!!!!!!! br taoufik |
in both of the ic's these pins have connection. |
dear in Z4403 pin 09-19 are empty , so change the both filters , prob will be solve rashid |
rashid |
1 Attachment(s) Quote:
bro, in Z4402 and Z4403 the pins 9 and 19 have connections |
i know you have knowledge , and appreciate your work , but read schematic. that is empty point i think , second we are only discussing , plz don't mind it . coz members want share with us . may this way they gain something. 3rd i did not criticized negatively . plz keep in mind rashid |
BE SENSIBLE, READ CAREFULLY SCHEMATIC U WILL FIND GOOD RESULT .IF U R NOT SATISFY WITH SCHEMATIC THEN U CAN CHECK IT BY URSELF BY REMOVUNG BOTH IC'S FROM THE BOARD AND THEN CHECK THE CONTINUITY FROM DISPLAY IC PRINTS TO THE DISPLAY CONNECTER .IF U FIND ANY CONNECTIVITY THEN POST UR RESULT HERE OTHERWISE CHECK BEFORE POSTING .HOPE U TAKE IT AS A POSTIVE . a little ADVICE to a member means a BIG HELP to them... |
i got this |
ok, checking procedure is correct but ur counting trick is wrong.we count it left to right. |
