01-27-2007, 17:32 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: india
Member: 239168 Status: Offline Thanks Meter: 104 | 3650 When Turn On "nokia-white Screen-nokia-whitescreen" Repeats I FLASHED IN UFS AND GOT LOGS AS BELOW 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,0001257E,Amd 29BDS643GT Fl1: 0x02000000-0x027FFFFF,0001257E,Amd 29BDS643GT Fl2: 0x04000000-0x047FFFFF,0001257E,Amd 29BDS643GT Algorithm: w2_amd.fia, w2_cbusb.fia, Ver: 4.49.0 Algorithm Ok, MSID: 8419D7FC49902A2504B781A276 Decoded MSID: 3E4EBAF7-00C6EF14-A8000000 Encoded FAID: 4FC8F075-CA802CB1-0FDD3100 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x006FFFFF Erased, Time: 01:16 Area3: 0x02000000-0x023FFFFF Erased, Time: 00:40 Area4: 0x04000000-0x046DDFFF Erased, Time: 01:12 BT MCM (21) Image Found: 0x0002DD00 BT MCM Registering Done MCU Flashing Completed, Time: 03:41 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x04730000-0x047FFFFF Erased, Time: 00:09 Area3: 0x00700000-0x0074BFFE Erased, Time: 00:03 PPM Flashing Completed, Time: 00:13 Flashing Completed, Rebooting Mobile Set Full Factory Defaults Ok, Time: 00:50 IMEI: 351102-10-094159-9, ASIC: 5 SimLocks Initialized, 00, Time: 00:02 User Area Format Ok, Time: 00:53 ALL SOFTWARE FLASHING-UI SETTINGS-USER AREA FORMAT R OK-NO PROBLEM-U CAN SEE IN ABOVE SO I THINK MY SETS PROBLEM IS HARDWARE.AM I CORRECT?ANY OTHER IDEAS TO SOLVE MY PROBLEM? THANK U. |
01-27-2007, 20:29 | #4 (permalink) |
Junior Member Join Date: Nov 2005
Member: 200467 Status: Offline Thanks Meter: 12 | In place of selecting the mcu and pmm files select the erase file and click on flash button.The again flash the mobile phone use proper flash file.Don't forget to write the pm file |
01-27-2007, 20:59 | #5 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | 1 select mcu file 3650flash0flash1flash2erase.bin , flash button 2 select mcu, ppm file the correct files , flash button 3 write 3650 pm 4 init simlocks 5 set full factory, sw upgrade defaults , and init normal mode in UI settings |
01-28-2007, 04:17 | #6 (permalink) |
No Life Poster Join Date: Sep 2006 Age: 41
Member: 356202 Status: Offline Thanks Meter: 46 | all posted solution are good... you may try this also.. fullfactory defaults 5 times..... init locks.... if this didnt work... CCSerase file.... then fullflash.. fulfactory default init locks.. wbr |
01-28-2007, 05:31 | #7 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 46
Member: 138982 Status: Offline Thanks Meter: 138 | here is fuul solution for flashing 3650 this was invented by our senior forum member not by me thanks salim |
The Following User Says Thank You to sallupat For This Useful Post: |
01-28-2007, 07:04 | #9 (permalink) |
No Life Poster Join Date: Jun 2006 Location: sn,fdo,lu philippines
Member: 288470 Status: Offline Sonork: 100.1605122 Thanks Meter: 664 | dont try to hardware its only software flash yhe phone in jaf the full factory settings and file system format phone will be ok if not do this methods 50x |
01-28-2007, 07:53 | #10 (permalink) | |
Member: 239168 Status: Offline Thanks Meter: 104 | Quote:
For Nhl8 (3650 & 3660) 01 - Download the ATTACHED FIILE 02 - Rename NHL8_Erase_PM.txt to NHL8_Erase_PM.zip 03 - Extract the file to "C:\Program Files\Nokia\Phoenix\Products\NHL-8" >>> 5 files <<< = _01 - NHL8 Flash0Flash1Flash2 ERASE.fia = _02 - NHL8 LFFSErasePMM.fia = _03 - NHL8 CCSErasePMM.fia = _3650.pm = _3660.pm 04 - Flash (MCU) the "_01 - NHL8 Flash0Flash1Flash2 ERASE.fia" , don't flash any PPM 05 - Flash (MCU) the "_02 - NHL8 LFFSErasePMM.fia" , don't flash any PPM 06 - Flash (MCU) the "_03 - NHL8 CCSErasePMM.fia" , don't flash any PPM 07 - FULL FLASH MCU "NHL83041.7C1" & PPM "NHL83041.701" 08 - FULL Factory Defaults 09 - Format User Area 10 - Wr PM (_3650.pm for 3650 / _3660.pm for 3660) 11 - Init SimLocks 12 - YOUR PHONE NOW BE OKAY ! my two sets r ok by above steps-thank u | |
6060 Turn On Only White Screen Then Turns Off | zonetrichur | Nokia Digital Core Technology 4 ( DCT-4 ) | 5 | 02-02-2007 16:22 |
6060 Turn On Only White Screen Then Turns Off | zonetrichur | UFS2 + UFS3-Tornadoflasher | 3 | 06-15-2006 10:17 |
SEk750 - Problem when turn on phone - white screen | b:z | Sony Ericsson | 3 | 12-05-2005 09:58 |
