Old 08-10-2009, 14:06   #1 (permalink)
Boyofkashmir's Avatar
Member: 642074
Thanks Meter: 1,953
N70 new white light problem
i recive 3 N70 white light i jumper both ic but still same but when i little bit heat near boot ic set works after few minutes set hang and then after agaib white,,,,,,,anyone hv sol?????
Old 08-10-2009, 14:34   #2 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,374
Bro.reball combo...........many time it..........
resalt post here............
Old 08-11-2009, 08:18   #3 (permalink)
Member: 642074
Thanks Meter: 1,953
Whr is combo...........................................
Old 08-11-2009, 08:37   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Bro.try it.............
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 08-11-2009, 08:45   #5 (permalink)
cel_phon's Avatar
Member: 950201
Thanks Meter: 1,925
COMBO
Old 08-11-2009, 10:12   #6 (permalink)
Member: 392792
Sonork: lasa_dal
Thanks Meter: 8
Dear friend
check the display connector with a multy meeter risistance to the ground (in diode scale)
all the pins should display some value in the meeter.
if any pin doesnt show a reading it means that line is not coming from the filters or derectly from CPU. if all ok proseed weth da combo
good luck!!
The Following User Says Thank You to lasa_dal For This Useful Post:
N70 In white light mode deep_6111 Nokia Hardware & Hardware Repair 12 09-05-2009 03:49
n70-1 white light plz help leomuns Nokia Hardware & Hardware Repair 11 02-03-2009 16:12
n70 stay white light sonumobilewala Nokia Base Band 5 ( BB-5 ) 5 08-27-2008 07:13
N70 only white light raj_cxe Nokia Base Band 5 ( BB-5 ) 2 03-26-2007 08:23
Page generated in 0.24142 seconds with 8 queries
