n70 no signal i have n70 show no signals i search network manually and after search show all networks BUT... no access to any network plz help me |
n70 no access 1 Attachment(s) n70 no access solution |
answer is here: how this problem occurs?? first you shoul try software, full flashing and write pm if still same rehot or reball inku and hinku ic (under camera, right of mmc socket) then change pfo and apply arun's solution. |
1 Attachment(s) Quote:
Br Boim80 |
i have n70 no signal i search manually its ok but no access pls any one show some pic. thanks |
try to reball the hinku ic or change it 10000% work for u all.... try it.... WinD:) |
I also have the same problem. Thing is, I already brought it to Nokia Care, and they told me that a cristal ic needs to be replaced, but it is next to a power ic which may further damage the phone. Will boim80's solution work for my problem as well? |
I have N70 no Network, but 3G is highlighted, I don`t know what to do. Please help me in this purpose. |
@..:ARUN:.. I try your solution and it works for me Thankyou... |
Best Regard WinD:) |
bro, n-70 is bb5 set. and all bb5 set is risky to erase |
try to change pa if your problem is same then change hinku and vinku ic best of luck |
IF YOU Search The Networks Manually and It SHow All NetworksBut when you choose Your Network It Dont Want To Access THEN ITS THE (PA) CHANGE IT , AND WHEN YOU HEATING HEAT FROM THE UNDER CUZ THE (PA) IS SOO SENSTIVE AND IT DAMGED WHEN YOU HEAT ON IT :) |
