Old 06-03-2007, 18:18   #1 (permalink)
Member: 275352
Thanks Meter: 17
n70 not charging
anybody pls help me about n70 not charging? its shorted circuit the charging line, thnks
The Following User Says Thank You to blue_moon22 For This Useful Post:
Old 06-03-2007, 18:25   #2 (permalink)
Euan's Avatar
Member: 492345
Sonork: 100.1594007
Thanks Meter: 161
try to change retu..........
Old 06-04-2007, 06:10   #3 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
Dear brother check it and post the result
The Following 7 Users Say Thank You to meo786pk For This Useful Post:
Old 06-04-2007, 06:27   #4 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
i agree with meoo thavo ic is responsible for charging problem mostly and not ritu
Old 06-21-2007, 11:13   #5 (permalink)
odraregnivla's Avatar
Member: 289554
Thanks Meter: 62
not working for my prob
the charging input is shorted
i remove ic,capasitors etc........ still
what is the posible problem..
thanks.............
Old 06-21-2007, 12:15   #6 (permalink)
Member: 93632
Thanks Meter: 8
remove the PA and see whether it is still there
The Following User Says Thank You to pter_f For This Useful Post:
Old 06-21-2007, 15:16   #7 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
thanks.............
TAKE OUT THE TAHVO REBALL OR CHANGE UR PROBLEM WILL BE SOLVE .
Old 06-21-2007, 16:36   #8 (permalink)
Member: 275352
Thanks Meter: 17
thanks u guys
thanks u guys i got an idea because before i don't have a schematics, i appricete
Old 06-21-2007, 21:47   #9 (permalink)
Member: 503683
Thanks Meter: 3
2100 contact service pls help me solve it
Old 06-21-2007, 23:13   #10 (permalink)
saiftc2's Avatar
Member: 231662
Sonork: 1607488
Thanks Meter: 390
IF YOU FINED SHORT CIRCUT ON CHARGE CIRCLE THEN REMOVE CRISTAL IC (V2000)
FORUMS.GSMJOMAN.COM
Tc
Old 06-28-2007, 07:39   #11 (permalink)
Member: 14307
Thanks Meter: 3
Everybody , just do this = remove f2000, take a wire connect charging point + (positive) to L2000, you will be charging again.
Old 06-28-2007, 07:45   #12 (permalink)
nmbaiju's Avatar
Member: 246200
Thanks Meter: 104
n70 not charging
pls upload pm file
thanks
baiju abraham mumbai
Old 07-11-2007, 09:24   #13 (permalink)
Member: 118190
Thanks Meter: 4
STUPID ANSWER !!!!!!!!!!!!!!!!!!!!!!!
should be CUT OFF the charging point then make jumper straight from the CHARGING CONNECTOR!!!!! WHAT<S WRONG WITH PA???? THIS IS CHARGING PROBLEM!!!!!!!!!!!!: mad:
Old 07-27-2007, 23:01   #14 (permalink)
Member: 503683
Thanks Meter: 3
hi i have on sonny erricson t630 the key pad is not working i have change the key pad circuit still some one help me pls
Old 07-29-2007, 15:01   #15 (permalink)
Member: 118190
Thanks Meter: 4
change the ic all around the kaypad connecter . should be ok
n70 not charging jimmy indra Nokia Hardware & Hardware Repair 8 04-15-2011 19:07
***N70 not charging*** meisam Nokia Hardware & Hardware Repair 7 08-28-2010 11:00
n70 not charging vhineze2k7 Nokia Hardware & Hardware Repair 6 07-05-2008 16:30
help n70 not charging shachash Nokia Hardware & Hardware Repair 13 01-31-2007 19:36
N70 Not Charging ashok_kumar459 Nokia Base Band 5 ( BB-5 ) 7 01-09-2007 06:15
Page generated in 0.23041 seconds with 10 queries
