N70 not charging solution Unit: N70 Fault: Not Charging Diagnosis & History: Shorted charging interface of PCB/Water Damage Action Taken Part1: Cut the charging track of the PCB as shown below http://i207.photobucket.com/albums/b...p22edz/CH1.jpg |
Action Taken Part2 : Make a new lay-out as seen in the pics below 1- After cutting the "track/charging lay-out" of the pcb, add tape as seen in the pic... http://i207.photobucket.com/albums/b...2edz/Image.jpg 2- Improvised a new lay-out as seen in the pic... http://i207.photobucket.com/albums/b...edz/Image1.jpg |
[QUOTE=upp22edz;9301]3- connect the improvised lay-out as seen in the pic http://i207.photobucket.com/albums/b...p22edz/ch5.jpg Problem Solved: |
just a little observation, your title did not fit the contents of your thread...which is which by the way...;) |
what's repaired here, can u explain more, as i see u just remove a track and add the same !!! thx |
Thread failure??? cya |
bloedman bgr ? sry for offtopic but this threat... is something wrong at all :D |
TO: Mods please change the thread title to its appropriate thread... ty. |
check your thread title sir br |
your thread title is wrong. |
Solid ,really Great Work,keep It Up,but Next Time Plz Check Or Topic Before Posting, |
Nice, I can unblacklist (change IMEI) a BB5 by changing the charging track? Sweet!;) |
not problem check your thread title sir |
perfect solution... thanx sir.. ;) ;) b.r. |
sir may kulang po sa explanasyon nyo kya magtataka ang ibang lahi... |
