Old 02-25-2008, 11:40   #1 (permalink)
amar22ado's Avatar
Member: 230087
Thanks Meter: 370
N70 not charging solution
Unit: N70
Fault: Not Charging
Diagnosis & History: Shorted charging interface of PCB/Water Damage
Action Taken Part1: Cut the charging track of the PCB as shown below
The Following 2 Users Say Thank You to amar22ado For This Useful Post:
Old 02-25-2008, 11:49   #2 (permalink)
amar22ado's Avatar
Member: 230087
Thanks Meter: 370
Action Taken Part2 : Make a new lay-out as seen in the pics below
1- After cutting the "track/charging lay-out" of the pcb, add tape as seen in the pic...
2- Improvised a new lay-out as seen in the pic...
Old 02-25-2008, 11:51   #3 (permalink)
amar22ado's Avatar
Member: 230087
Thanks Meter: 370
[QUOTE=upp22edz;9301]3- connect the improvised lay-out as seen in the pic
Problem Solved:
Old 02-25-2008, 12:39   #4 (permalink)
Member: 257511
Thanks Meter: 69
just a little observation, your title did not fit the contents of your thread...which is which by the way...
Old 02-25-2008, 13:40   #5 (permalink)
BouRRi_GSM's Avatar
Member: 111457
Thanks Meter: 937
what's repaired here, can u explain more, as i see u just remove a track and add the same !!!
thx
Old 02-25-2008, 14:21   #6 (permalink)
Bloedman's Avatar
Member: 67905
Thanks Meter: 17
Thread failure???
cya
Old 02-25-2008, 21:52   #7 (permalink)
Member: 151397
bloedman bgr ? sry for offtopic but this threat... is something wrong at all
Old 02-26-2008, 12:24   #8 (permalink)
amar22ado's Avatar
Member: 230087
Thanks Meter: 370
thx
charging interface of the PCB is shorted... so I made a new lay-out...
TO: Mods
please change the thread title to its appropriate thread... ty.
Old 02-26-2008, 13:00   #9 (permalink)
raezak's Avatar
Member: 260632
Thanks Meter: 621
check your thread title sir
br
Old 02-26-2008, 13:37   #10 (permalink)
Member: 659658
Thanks Meter: 11
your thread title is wrong.
Old 02-26-2008, 17:52   #11 (permalink)
san9090's Avatar
Member: 697664
Sonork: 100.1602716
Thanks Meter: 256
Solid ,really Great Work,keep It Up,but Next Time Plz Check Or Topic Before Posting,
Old 02-27-2008, 12:41   #12 (permalink)
Speed_Demon's Avatar
Member: 249757
Sonork: 100.1601084
Thanks Meter: 117
Nice, I can unblacklist (change IMEI) a BB5 by changing the charging track?
Sweet!
Old 03-03-2008, 02:09   #13 (permalink)
Member: 655840
not problem check your thread title sir
Old 03-04-2008, 08:38   #14 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,563
perfect solution... thanx sir..
b.r.
Old 03-05-2008, 03:51   #15 (permalink)
Registered User
Member: 557494
Thanks Meter: 14
sir may kulang po sa explanasyon nyo kya magtataka ang ibang lahi...
The Following User Says Thank You to dhenz_y For This Useful Post:
n70 not charging jimmy indra Nokia Hardware & Hardware Repair 8 04-15-2011 20:07
***N70 not charging*** meisam Nokia Hardware & Hardware Repair 7 08-28-2010 12:00
N70 Not Charging Alternative Solution frooze_angel Nokia Hardware & Hardware Repair 8 11-19-2008 14:52
K300 Charging but not Charged Solution wsw243 Sony Ericsson Hardware Repair 0 07-27-2007 03:28
help n70 not charging shachash Nokia Hardware & Hardware Repair 13 01-31-2007 19:36
Page generated in 0.47348 seconds with 8 queries
