02-01-2010, 11:04 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 777756 Status: Offline Thanks Meter: 44 | n70 phone start up failed Detected PKEY: 90009D9B Card life counter: 26.52% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 20416, Library version: 30118 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.8.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. HW version: 6001 PCI version: RFIC version: 150a160f DSP version: rolf_05wk07v29p1 Retu version: 32 Tahvo version: 53 Production serial number: CIH650920 Product code: 0524086 Module code: Basic production code: 0522156 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 356294011574695 IMEI spare to net: 3A 65 92 04 11 75 64 09 IMEI SV to net: 33 65 92 04 11 75 64 19 F2 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-84.ini Saved INI not found, loading INI list... Setting local mode... Reading product code... Product Code: 0524086 Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-84\ Scanning for ini files... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.C0 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-84\RM84_50737301.V05 CNT Flash file: NONE APE Variant file: ? Done! Setting test mode... Failed! Aborting! Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 4 seconds... Done! Setting test mode... Resetting USER DATA... Operation took 0 minutes 0 seconds... Done! Init phone communication... Setting test mode... Detecting File System... |
02-01-2010, 11:12 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: Dubai(U.A.E) Age: 37
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | use zulea carck 2.01 repair SL ur problam solve link here http://www.ziddu.com/download/688595...yzulea.zip.htm |
02-01-2010, 11:17 | #3 (permalink) |
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | new link here http://rapidshare.com/files/21529564...E_by_Zulea.zip |
02-01-2010, 11:42 | #4 (permalink) |
Member: 777756 Status: Offline Thanks Meter: 44 | no buddy it is same after it i tried to repair sl zone it said ok but problem same .one thing i also want to share when i put mobile on jaf it dosnt show phone startup it works ok then but with battery it says |
02-01-2010, 12:38 | #7 (permalink) |
Member: 777756 Status: Offline Thanks Meter: 44 | Searching for JAF box ... JAF box detected Box firmware version: 1B1 Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-84 Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294011574695 SP LOCK status: Config Key: 0000000000000000 Provider Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Block 2: OPEN Type 5 Data: 23594F Block 3: OPEN Type 5 Data: 23420F Block 4: OPEN Type 5 Data: 23594F Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-84 Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294011574695 SP LOCK status: Config Key: 0000000000000000 Provider Key: 2342000000000000 Counters: 0/3, 0/10 Phone is Unlocked Reading PM Field 308 Subfield 1 with length 4096 bytes Saving to file: RM-84_356294011574695_PM308_Unlocked_01-02-2010_170757.bin Saving to file: RM-84_356294011574695_308_Unlocked_01-02-2010_170757.pm PM308 backup OK BB5 FLASH bb5challenge ... ASIC ID: 000000010000022600010006000C192101002200 HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D CMT Boot Ready HELLO start ok HELLO HELLO PM send. Test call... cpsr - 0x0000001F p15_1 - 0x0005307F p15_2 - 0x0005117F p15_3 - 0x0005317F esn_init ret - 0x00000001, <tmp_buff2> - 0x00000001 esn_read ret - 0x00000001, <tmp_buff2> - 0x00000001 Normal BB5 found - 0x006E1CD0 LR - FFFF2C68, param - 0x03, size - 0x00 UpdSLock - 0x00000001 ret - 0x01, <tmp_buff2> - 0x23 PM_308 CRC - 0x000D3D6E Reciving PM PM buff recived After unlock. Searching for phone ... Phone found on FBUS interface Writting PM Field 308 Subfield 1 with length 4096 bytes Reset phone ... PM Field 308 Subfield 1 written OK Searching for phone ... Phone found on FBUS interface Reading phone info ... Type: RM-84 Version: V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. IMEI: 356294011574695 SP LOCK status: Config Key: 0000000000000000 Provider Key: 2342000000000000 Block 1: OPEN Type 5 Data: 23420F Block 2: OPEN Type 5 Data: 23594F Block 3: OPEN Type 5 Data: 23420F Block 4: OPEN Type 5 Data: 23594F Counters: 0/3, 0/10 Phone is Unlocked Read Phone Info OK Successfully done. |
n70 phone start-up failed | zahed1978 | Nokia Hardware & Hardware Repair | 7 | 07-22-2008 18:17 |
N70 phone start-up failed | usernome | Universalbox | 1 | 07-29-2006 00:44 |
N70 phone start-up failed | mobilegsm30 | MT-BOX | 5 | 03-30-2006 07:53 |
