05-01-2009, 11:10 | #1 (permalink) |
Insane Poster Join Date: Dec 2008 Location: ULUNDURPET ,INDIA Age: 41
Member: 928991 Status: Offline Thanks Meter: 20 | n70 phone startup failed contact the retailer fault n70 1 st come display white ,than i check and change display ic both set 100%ok. i give to customer these n70 then after few minites ,change another sim set SHOWING PHONE STARTUP FAILED CONTACT THE RETAILER. THEN IAM CHECKING,PHONE LOCK OR NOT IN BB5 KING SHOWING PHONE IS UNLOCKED,THEN IAM TRYING HAND FARMATE ,HWK USER AREA FARMATE ,JAF FILE SYSTEM FARMATE,MT BOX FARMATE,NO USE, AND THEN FULL FLASH ,BEFORE FLASH BACKUP PM FROM N70.AND THEN WRITE PM USING JAF .BUTTTTTTTTT THESE FAULT IS CONTINUING. |
05-09-2009, 16:05 | #6 (permalink) |
Member: 928991 Status: Offline Thanks Meter: 20 | n70 info MCU SW : V 05wk07v48.1 28-08-07 RM-84 (c) Nokia. APE Core: V 5.0737.3.0.1 13-09-07 RM-84 (C)Nokia APE Var : V 5.0737.3.0.1-02.01 13-09-07 RM-84 (c)Nokia. Prd.Code: 0524110 Bpr.Code: 0522156 Prod.Sn : SCK579898 HW Vers : 6061 APE HW : 256 APE Adsp: 16054 EM RETU : 32 EM TAHVO: 52 RFIC Ver: 150a160f DSP Vers: rolf_05wk07v29p1 LCD Type: 2727964 IMEI : 351862-01-680554-9 SL Serv : SIMLOCK SERVER VERSION 58 SL Conf : 234-20-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN BLK2= L1: OPEN BLK3= L1: OPEN BLK4= L1: OPEN Provider: Hutchinson 3G (3);United Kingdom |
06-12-2011, 11:07 | #11 (permalink) |
Crazy Poster Join Date: Jul 2009 Location: bangladesh naogaon Age: 43
Member: 1071534 Status: Offline Thanks Meter: 9 | n-70 phone startup fail contact the retailer solution 100% brother use mx-key step 1 = go to service==pm===repair sd ===then sd repair ok go step 2 step 2 = load from pm == select good pm == pmm auth== then pmm auth ok go step 3 step 3 == write pm oparation ok 100% testade |
7650: Phone startup failed. Contact the retailer problem | jignesh_1000 | Griffin | 9 | 09-25-2005 15:11 |
7650: Phone startup failed. Contact the retailer. | Greatgonzo | Griffin | 7 | 06-24-2004 11:39 |
