Old 07-02-2009, 01:14   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::n70 prints missing under tahvo::..
n70 no lcd light,the p3 prints under tahvo on pcb are missing,these prints cause lcd and keypad light failure?
the points which i circle
Old 07-02-2009, 03:14   #2 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
its urgent mates.........................
Old 07-02-2009, 07:05   #3 (permalink)
habibuddin's Avatar
Member: 441231
Thanks Meter: 206
bro. only no lcd light? led light ok? Lcd & Led no light u should change first light coil which is right side of
display ic. Maybe p3 prints in tahavo ic no problem create on light.
habibuddin
Old 07-02-2009, 07:34   #4 (permalink)
oblio's Avatar
Member: 59869
Thanks Meter: 132
A1-VPP_IO not used
B1-CbusSelX used ->SerSelX(RETU)&CBusEn1X(RAP3G)
K3-VM_CLK ->USBVM_Clk(RAP3G)&usb0_vm(OMAP)
So nothing to do with lights.The important pad of Tahvo in this case is G1(PWM300) wich has to be connected to J2309 and A2 of N2301.
If you already changed N2301, then most probably the fault is L2304 wich can be easily burned on high temperatures.
You're too old in forum, so I will not put links to service manuals, you probably have them...
Old 07-02-2009, 08:09   #5 (permalink)
oblio's Avatar
Member: 59869
Thanks Meter: 132
UPSSS, I made a mistake, wrong counting the pins (I thought is ball view, but is top view).
So the missing pads are A1, A2 and C10, NONE of them used here, so nothing to do with the lights!
Sorry again...
The Following User Says Thank You to oblio For This Useful Post:
Old 07-02-2009, 10:09   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
thnx oblio
..::6303c some prints missing under betty ic::.. HUM Nokia Hardware & Hardware Repair 17 10-16-2009 22:41
..::n70 print missing under display ic::.. HUM Nokia Hardware & Hardware Repair 2 09-07-2009 23:03
..::6120c print missing under rf ic::.. HUM Nokia Hardware & Hardware Repair 5 07-02-2009 10:47
..::n70 Prints Under Keypad Ic Are Damaged::.. HUM Nokia Hardware & Hardware Repair 5 06-28-2008 17:03
1110 2 tracks missed under light ic hany elsaghir f Nokia Hardware & Hardware Repair 6 03-07-2007 14:45
Page generated in 0.24283 seconds with 10 queries
