..::n70 Prints Under Keypad Ic Are Damaged::.. 1 Attachment(s) n70 prints under keypad ic on circuit are damaged. |
Hi Hum Just Use Sharp Blade And Be Careful And Cut Into Board Until You See The Copper Then Tint It With Soldering Iron And Build Up Solder.use Lots Of Flux If You Gonna Replace Filter.if You Using Jumper No Flux Just Solder Wire Direct.i Do This All The Time 100000% Success Post Result Hope Its Helps You.. |
i agree with u,but its too much damage no way to scratch bcoz if i try it will be ground. |
anyone have ways for these damage prints? |
1 Attachment(s) Use microscope u can see that thin circuit , scratch lightly do jumper . Hope it help ..... good luck ! |
