Old 06-26-2008, 20:53   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,228
..::n70 Prints Under Keypad Ic Are Damaged::..
n70 prints under keypad ic on circuit are damaged.
Old 06-26-2008, 23:12   #2 (permalink)
Member: 45716
Thanks Meter: 38
Hi Hum Just Use Sharp Blade And Be Careful And Cut Into Board Until You See The Copper Then Tint It With Soldering Iron And Build Up Solder.use Lots Of Flux If You Gonna Replace Filter.if You Using Jumper No Flux Just Solder Wire Direct.i Do This All The Time 100000% Success Post Result Hope Its Helps You..
Old 06-27-2008, 00:29   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,228
i agree with u,but its too much damage no way to scratch bcoz if i try it will be ground.
Old 06-27-2008, 09:47   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,228
anyone have ways for these damage prints?
Old 06-28-2008, 09:51   #5 (permalink)
Member: 117956
Thanks Meter: 107
Use microscope u can see that thin circuit , scratch lightly do jumper . Hope it help ..... good luck !
The Following User Says Thank You to tgcommss For This Useful Post:
Old 06-28-2008, 18:03   #6 (permalink)
Member: 461923
Thanks Meter: 2,015
..very good man ...............
nokia 6280 numeric key pad ic print is ok but frornt panel keypad ic print is broken Matwala Nokia Hardware & Hardware Repair 2 07-22-2012 09:09
..::n70 Keypad Ic Prints On Circuit Are Destroyed::.. HUM Nokia Hardware & Hardware Repair 12 04-01-2010 12:41
..::n70 print missing under display ic::.. HUM Nokia Hardware & Hardware Repair 2 09-08-2009 00:03
..::n70 prints missing under tahvo::.. HUM Nokia Hardware & Hardware Repair 5 07-02-2009 11:09
..::1600 pcb keypad ic prints damaged::.. HUM Nokia Hardware & Hardware Repair 4 05-02-2009 08:16
Page generated in 0.31471 seconds with 9 queries
