04-16-2007, 10:56 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: iran
Member: 194370 Status: Offline Thanks Meter: 168 | n70 restart |
04-16-2007, 19:42 | #5 (permalink) |
Insane Poster Join Date: May 2006 Location: VISHAKAPATNAM,andhrapredesh Age: 41
Member: 277335 Status: Offline Thanks Meter: 4 | n70 restart solution try to format the phone by useing * * # cal button poweron button (press all the 4 buttons simultaniously) on the screen nokia will appiar it blinks 2 to 3 times and phone will start ,till the end of the procidure dont leave the buttons,keep all the 4 buttons on pressing ,remove sim and memory before starting he operation,format the mmc card also ,ur problem will be 100% solved best regards,br dukesaran |
04-17-2007, 10:27 | #6 (permalink) | ||
Member: 194370 Status: Offline Thanks Meter: 168 | Quote:
04-17-2007, 15:57 | #7 (permalink) |
Freak Poster Join Date: Apr 2007 Location: INDONESIA
Member: 486960 Status: Offline Thanks Meter: 45 | N70 restart maybe caused so many reasons. Software problem, Viruses, and may be hardware problem. I just explain one possibility of hardware problem that can make a handphone restarted. There is something wrong in regulator may cause this problem. The regulator supply electric current for an IC. In N70 's sensitive regulator is regulator for OMAP IC. To verify the regulator try to check the stability of the voltage with an osciloscope. If the voltage is not stable, change the N4200. |
04-18-2007, 17:50 | #9 (permalink) | |
i try to change this ic but not ok please help | |
n70 restart | sepid | Nokia Base Band 5 ( BB-5 ) | 25 | 10-12-2006 19:04 |
n70 restart | chotky | Nokia Base Band 5 ( BB-5 ) | 2 | 05-21-2006 14:04 |
n70 restarting | fatho | Nokia Base Band 5 ( BB-5 ) | 8 | 02-22-2006 16:57 |
N70 restarts with memory card | dominik | Nokia Base Band 5 ( BB-5 ) | 0 | 02-10-2006 17:39 |
N70 restarting | vitpod | Universalbox | 2 | 01-14-2006 17:51 |
