Old 04-07-2009, 12:46   #1 (permalink)
Member: 820680
Sonork: 1623541
Thanks Meter: 3
N70 startup failed contact retailer
i have n70 ,( water damage) i cleaned it well and when it switched on it shows NOKIA two times and after that it shows "phone start up failed contact Retailer" i flashed it with jaf and after that it shows the same.
Old 04-07-2009, 13:23   #2 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
bro cheack sp data and iemi 12345678
The Following User Says Thank You to ..::ohm::.. For This Useful Post:
Old 04-07-2009, 14:00   #3 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
BRo.........1st good sarvising the set..........after.........set formet the jaf........result post here.........
The Following 2 Users Say Thank You to mahbubalfa For This Useful Post:
Old 04-07-2009, 15:08   #4 (permalink)
p.suresh's Avatar
Member: 482019
Thanks Meter: 100
format user aria on ufs
The Following User Says Thank You to p.suresh For This Useful Post:
Old 04-07-2009, 15:22   #5 (permalink)
Member: 645970
Thanks Meter: 157
dear, try U.B for this fault, i tried many time approx 16 or 17 times... dear full flash it with with upgrade version............ after flash just format it...... after format sucess.... just creat factory setting........ an take jump for normal mode....... i think you will sucess..... " IF NOT SUCESS POST LOG HERE"..... BRO..........
The Following User Says Thank You to ashish mobile For This Useful Post:
Old 04-07-2009, 15:42   #6 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
brother first backup crt and rpl
then full erase fone
then flas letest flas file
then write pm use sx4
then format fone
then ui setting
good luck
Old 04-07-2009, 15:50   #7 (permalink)
shahidsattar's Avatar
Member: 388454
Thanks Meter: 1,101
check imie no. .... if corrupted the write rpl
Old 04-07-2009, 16:59   #8 (permalink)
Member: 820680
Sonork: 1623541
Thanks Meter: 3
i have no uni box ihave only jaf and ufs
Old 04-07-2009, 17:02   #9 (permalink)
Member: 820680
Sonork: 1623541
Thanks Meter: 3
thanks but imei is currect 35956601526521
Old 04-07-2009, 17:04   #10 (permalink)
Member: 820680
Sonork: 1623541
Thanks Meter: 3
still its shown in the same
Old 04-07-2009, 17:34   #11 (permalink)
mahbubalfa's Avatar
Member: 1003058
Bro.....rehot flsh ic...& flash ic under 2 capasitor remove...this.......
Old 04-07-2009, 17:36   #12 (permalink)
mahbubalfa's Avatar
Member: 1003058
Bro.....result post here............
ashad420
Old 04-07-2009, 17:51   #13 (permalink)
Member: 963505
Thanks Meter: 50
1--u reball rap ic
2-- comboflash
solve your problem 110%
Old 04-07-2009, 18:28   #14 (permalink)
mohammed-anis's Avatar
Member: 751223
Sonork: mobilecenter88
Thanks Meter: 538
check info provider are found or not found not found so repair sp data ur problem solved 100000%
N70 startup failed... Contact Retailer ranz_28 Nokia Base Band 5 ( BB-5 ) 1 08-03-2009 12:02
n70 startup failed contact retailer CellTronic Universalbox 4 01-25-2008 01:19
n70 phone startup fail contact retailer fast_alex1123 Nokia Base Band 5 ( BB-5 ) 5 03-08-2007 21:21
startup faile contact retailer on n-gage jab UFS2 + UFS3-Tornadoflasher 8 02-24-2007 07:04
nokia 3650 'phone startup failed, contact retailer mailhassan WD2 & APE (Symbian Phones) 9 06-13-2004 02:05
Page generated in 0.22605 seconds with 10 queries
