01-21-2007, 11:16 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Age: 47
Member: 101007 Status: Offline Thanks Meter: 27 | N70 still white screen after all the solution and i've changed display diode few times flash wit latest firmware many times change diode near connector big and small and make jumper as the solution i've search from tis forum after made jumper phone cant on... soi hav to remove jumper.... it solve so many n70 but not tis one atleast not tis one now reball ram... replace new lcds still no display but can make and receive call pls any solution thanks |
The Following User Says Thank You to uneternity For This Useful Post: |
01-22-2007, 08:17 | #4 (permalink) |
Freak Poster Join Date: Oct 2006 Location: South Africa Age: 48
Member: 372599 Status: Offline Thanks Meter: 41 | yes... its not software problem... If u switch on phone and it hangs on white screen.. then solution is different.. but if u can make calls.. and phone works with showing display.. it is L.C.D or Display Ic.. which is the right side of crystle ic.. on board.. |
01-24-2007, 14:03 | #6 (permalink) | |
Freak Poster Join Date: Apr 2005
Member: 139043 Status: Offline Thanks Meter: 27 | Quote:
04-06-2007, 13:09 | #12 (permalink) |
Member: 139043 Status: Offline Thanks Meter: 27 | Do you think that i have time to joke about this sort of things? I have plenty of phones to fix. This is the site to learn and thats what i am doing right now. If you know the answer to my question, why dont you post it instead of posting things " are u joking man ?? " If you think you are clever enough to fix a phone you dont even have to come to this site and waste your time broswing, spend your time to fix your phones instead of posting rubbish HERE. |
04-14-2007, 09:09 | #13 (permalink) |
Member: 101007 Status: Offline Thanks Meter: 27 | no hard feelin pls jus share and chill the 10pin u can only use the one for n70 but the small one is 5pin u can use 72 camera ic for replacement most nk 5pin works fine but till now i still yet to solve my pro any pro pls helpppppppppppp regards |
04-14-2007, 11:00 | #14 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Dubai U.A.E.
Member: 324136 Status: Offline Thanks Meter: 99 | Quote:
Ape flash ic is glued so check this out maybe some help removing it http://forum.gsmhosting.com/vbb/showthread.php?t=391852 WBR Francis Rodrigues The Mobile King Team | |
04-14-2007, 13:03 | #15 (permalink) |
Registered User Join Date: Sep 2004 Location: INDIA Age: 48
Member: 83237 Status: Offline Sonork: 100.1577738 Thanks Meter: 61 | [QUOTE=uneternity;2214724]i've got one n70 white screen and i've changed display diode few times flash wit latest firmware many times change diode near connector big and small and make jumper as the solution i've search from tis forum after made jumper phone cant on... soi hav to remove jumper.... it solve so many n70 but not tis one atleast not tis one now reball ram... replace new lcds still no display but can make and receive call pls any solution thanks[/QUOTE after all try only two possible chance to repair white light, first chk omap cpu, 2nd one ape flash ic... |
W850 still white screen after successful flash.. | addictz | Sony Ericsson | 17 | 06-02-2010 05:27 |
7610 white screen all calls incoming outgoing flashed many version still white screen | GSMBALOCH | Nokia Hardware & Hardware Repair | 7 | 06-01-2009 20:54 |
K800 blinking white screen after flash the same | tgsm | Sony Ericsson Hardware Repair | 4 | 01-11-2008 05:02 |
