06-25-2008, 15:34 | #1 (permalink) |
Insane Poster Join Date: Apr 2007
Member: 487904 Status: Offline Thanks Meter: 12 | n70 strange charge problem i received n72 two month ago that had charge problem,i check it's charge connector and it was shorted - and + pins of charge connector ,then i remove all C2000 & C2012 & V2000 and charge works again but today customer come that phone again with same charge problem ,- & + pins of charger connector shorted here is picture of components that i removed ,signed with yellow circle i think that i must change TAHOV ,what's ur idea friends??? </div> |
The Following User Says Thank You to newstudent For This Useful Post: |
06-25-2008, 18:37 | #3 (permalink) |
Insane Poster Join Date: Aug 2006 Location: oman
Member: 330284 Status: Offline Thanks Meter: 29 | first u remove the fuse thn check +ve line short or not.if short change that diode.u must fix new diode otherwise after some days tavo ic will gone.it will show charging signal not charge store in battery. |
The Following User Says Thank You to pinkzgsm For This Useful Post: |
06-25-2008, 19:00 | #4 (permalink) |
Freak Poster Join Date: Sep 2007 Location: Sialkot Age: 39
Member: 578828 Status: Offline Thanks Meter: 88 | all sets if ur phone shurt plz chech ur batt connecter becuse if ur bat conecror conect the grund circut ur phone show the shurt ccircut...check |
The Following User Says Thank You to gsmawan For This Useful Post: |
06-26-2008, 14:03 | #5 (permalink) |
Member: 487904 Status: Offline Thanks Meter: 12 | i check battery connector,it's not shorted but charger connector in bottom of phone is shorted,i remove all parts in charge way but it's shorted yet i think that TAHOV must be change,pls see my picture and parts that i removed ,and help me |
06-26-2008, 18:24 | #8 (permalink) | |
Member: 487904 Status: Offline Thanks Meter: 12 | Quote:
i trace charge track and remove all components that can make problem,except TAHOV and it seem that TAHOV is responsible for this i'll change it and post result </div> | |
06-27-2008, 09:32 | #9 (permalink) |
Member: 487904 Status: Offline Thanks Meter: 12 | i removed TAHOV ,and board is without this ic but it's still shorted,i confused as u see in charge ways in my attached picture,there is nothing else except F2000 & L2000,but charger connector (X2000) ,is shorted still. pls help me,where is malfunction ???!!!!! |
06-27-2008, 10:24 | #11 (permalink) | |
phone is turned off,there is any software running ,it is 100% hardware problem,there is short circuit problem, WE ATTEMPT TO FIND SHORTED POINT don't misleading us thx for ur help PLS HELP ME </div> | |
N70 strange display problem | ahkhoo76 | Nokia Hardware & Hardware Repair | 4 | 04-14-2009 11:24 |
n70 strange network problem | jignesh269 | Nokia Hardware & Hardware Repair | 4 | 09-09-2007 01:53 |
Strange charging problem | SaltyNYH | Siemens Hardware Repair Area | 1 | 02-21-2003 21:26 |
3210 strange charging problem | patrynio | Nokia Hardware & Hardware Repair | 0 | 08-30-2002 17:30 |
