Old 02-20-2010, 12:15   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::n70 very low earpiece and disturbing earpiece sound::..
any tested solution
Old 02-20-2010, 12:32   #2 (permalink)
shakeeldawach's Avatar
Member: 471955
Thanks Meter: 201
Change RETU IC Mate.
Old 02-20-2010, 12:37   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
i try this trick but still same
The Following User Says Thank You to HUM For This Useful Post:
Old 02-20-2010, 13:07   #4 (permalink)
shaazad's Avatar
Member: 1146078
Thanks Meter: 96
yes brother its good sulution
Old 02-20-2010, 15:05   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
still same any other solution mates
Old 02-20-2010, 15:28   #6 (permalink)
shuaib_kashish's Avatar
Member: 405715
Thanks Meter: 271
yes i agree with you..change retu..the final solution..check outgoing voice with another phone.if outgoing voice also distorted,you should change mic and mic ic.
try and post reply............
Old 02-20-2010, 16:01   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
outgoing voice is ok
Old 02-20-2010, 17:38   #8 (permalink)
dr.lolo's Avatar
Member: 309944
Sonork: 1628185
Thanks Meter: 40
first u need to change mic then try to clean network compenent in the end try to change retu ice
Ust pro is very low flah and unlock quality box....................... ak72342 UST Pro II 5 01-23-2010 21:07
6630 buzzer & earpiece sound is very low ? .:: Sepid Gsm ::. Nokia Hardware & Hardware Repair 12 09-13-2008 11:47
..::1110 very low ring and loudspeaker::.. HUM Nokia Hardware & Hardware Repair 10 11-10-2007 08:53
After flash: Very low contrast and sim lock -luigi- UFS2 + UFS3-Tornadoflasher 3 11-03-2007 11:28
G50 very low ringtones... and problem is not ringer Burnt Cobba Panasonic 1 08-28-2004 00:39
Page generated in 0.16329 seconds with 9 queries
