04-05-2009, 15:46 | #1 (permalink) |
Junior Member Join Date: Mar 2009
Member: 1000781 Status: Offline Thanks Meter: 0 | N71 Bluetooth unable and drains batt easily all the resetting codes...even reflashed it. i have the new firmware but no avail.. i tried *#2820# it has no bluetooth serial no. address.. i hope u can help me on this..thanks!! |
04-05-2009, 17:10 | #2 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 681180 Status: Offline Thanks Meter: 18 | 1st replace bt ic for bt problem... for draining battery remove the small battery from the pcb and replace charging ic,,, flash it with latest verson.... i think ur problem will be solved.... |
04-06-2009, 20:24 | #5 (permalink) |
No Life Poster Join Date: Oct 2007 Location: nigeria kano
Member: 599669 Status: Offline Thanks Meter: 115 | bro just rehot the bt module if the problem still continue than change it from a dead n71 pcb.than or the fast drain of battry check for shortage on the pcb,if no shortage format your phone.all the best................ |
04-24-2009, 11:37 | #7 (permalink) |
Freak Poster Join Date: Dec 2007 Location: india
Member: 645970 Status: Offline Thanks Meter: 157 | did you check 20 - 30 OHMS on battery connector, or try to reflash by U.B, with enable B.T FLASHING option........ if the problems are continue.... change bt module with good one..... check ur set for shorting... dont forget to change battery also..... |
N71 Bluetooth unable to operate | fishbone08 | Nokia Hardware & Hardware Repair | 0 | 04-05-2009 15:49 |
3530 batt easily drain | dartanian | Nokia Hardware & Hardware Repair | 3 | 01-07-2007 16:37 |
6230 fast draining batt or batt low | hpcom | Nokia Hardware & Hardware Repair | 4 | 10-11-2006 05:43 |
Siemens C 30 Draining Batts Soln | gmps2003 | x1x to x45/x50 | 5 | 03-31-2004 14:48 |
bosch 509 batt easily drain? | eureka8888 | Hardware Repair by brands | 0 | 12-31-2001 11:20 |
