Old 08-25-2008, 01:14   #1 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
n72 keypad problem
i have n72 with keypad problem ...i had changed the keypad ic and cleaned the board but the keypad doesn't works ...anyone please help me...
Old 08-25-2008, 01:35   #2 (permalink)
AdickAsia's Avatar
Member: 801083
Thanks Meter: 99
Try remove or change key volume
post result
Old 08-25-2008, 08:04   #3 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
br simply change keypad ic solved your problem................
Old 08-25-2008, 17:47   #4 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
i had changed the keypad ic bro but stillkeypad not working ....
Old 08-25-2008, 17:59   #5 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
rehot key pad ic if not done change that.............
Old 08-25-2008, 19:04   #6 (permalink)
Member: 675717
Thanks Meter: 125
Try to change keyboard.Best of luck.
Old 08-26-2008, 15:29   #7 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
i had changed keypad ic and keyboard also any one please give any other solution
Old 08-26-2008, 15:33   #8 (permalink)
Member: 192146
Thanks Meter: 46
remove the small chip near keypad connector ad make a jumper on it!!!!!!!!!
Old 08-26-2008, 16:17   #9 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
not work eny key or sume of them not work?
Old 08-29-2008, 16:20   #10 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
can you please show the image.....
Old 08-29-2008, 18:03   #11 (permalink)
amardeepsahi's Avatar
Member: 357914
Thanks Meter: 71
which keys are not work properly,
please write
Old 08-29-2008, 18:20   #12 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
The Following User Says Thank You to pupaji For This Useful Post:
Old 08-29-2008, 20:54   #13 (permalink)
nisamknr2@yahoo's Avatar
Member: 625234
Sonork: 100.1604070
Thanks Meter: 90
only change cpu.i think ur mobile filldown
Old 09-10-2008, 20:39   #14 (permalink)
Member: 675717
Thanks Meter: 125
First cheeck track missing or not if missing make jumper if not rehot or reball rap 3g otherwise change rap 3g with flash chip.
Old 09-13-2008, 06:38   #15 (permalink)
aryan_'s Avatar
Member: 256027
Thanks Meter: 52
please write
all keys not are working
6700c keypad problem luyanda Nokia Hardware & Hardware Repair 20 04-09-2014 10:16
nokia n72 keypad problem vinkle Nokia Hardware & Hardware Repair 9 10-25-2011 08:34
N72 keypad problem shok9992000@yah Nokia Hardware & Hardware Repair 3 03-07-2008 16:14
n72 keypad problem smartengg Nokia Hardware & Hardware Repair 0 12-22-2007 10:56
n72 keypad problem (different) raj_cxe Nokia Base Band 5 ( BB-5 ) 1 10-25-2007 07:38
Page generated in 0.21822 seconds with 10 queries
