06-24-2009, 05:57 | #1 (permalink) |
Insane Poster Join Date: Jun 2008
Member: 800139 Status: Offline Sonork: papuia Thanks Meter: 30 | N72 problem my n-72, 10 mins after switching on the phone frequently it become death!! Any solution for my problem... it will be grateful for me if u can solve my problem.... |
06-24-2009, 06:37 | #3 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
request to post ur problem in simple and easy way do u mean that ur phone shut down automatically after 10 minutes....? if yes the first check the imei | |
06-24-2009, 07:57 | #5 (permalink) |
Member: 800139 Status: Offline Sonork: papuia Thanks Meter: 30 | JAF version 1.98.63 Detected PKEY: 900032BC Card life counter: 69.93% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 05wk07v48.2 04-10-07 RM-180 (c) Nokia. PCI version: RFIC version: 150a160f DSP version: rolf_espresso_05wk07v29p1 Retu version: 32 Tahvo version: 53 Production serial number: Product code: Module code: Basic production code: Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 12345610654321? IMEI spare to net: 1A 32 54 16 60 45 23 01 IMEI SV to net: 13 32 54 16 60 45 23 01 F9 LOCK STATUS: CONFIG KEY: 0000000000000000 PROVIDER KEY: 2342000000000000 Provider: Hutchinson 3G (3);United Kingdom Key Code count: 0, FBUS Code count: 0 Block 1: Lock 1: OPEN Block 2: Lock 1: OPEN Block 3: Lock 1: OPEN Block 4: Lock 1: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-180.ini Saved INI not found, loading INI list... Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Done! |
nokia n72 problem rm180 | amit.klag | Universalbox | 1 | 02-19-2008 18:02 |
n70 & n72 problems | vipimg | Nokia Hardware & Hardware Repair | 3 | 10-03-2007 11:28 |
n72 problem | RRRRR | MT-BOX | 3 | 08-01-2007 12:52 |
