12-02-2008, 11:38 | #3 (permalink) |
Registered User Join Date: Oct 2006 Location: egypt Age: 44
Member: 366590 Status: Offline Thanks Meter: 145 | There Is No Full And Perfect Way To Solve But This Can Help To Solve... Info About Contact Retialer In BB5 & SP Area Damaged & RPL Write Phone. Few Thinks U Have To See Before Repair. 1 Phone IMEI Is Damaged Or Not? F.E 123456789012345 2 Phone Sp Area Is Damaged Or Not? F.E Config key -FFFFFFFFFFFFFF & PROVIDER - unknown 3 Bb Self Test You Can Do With Service Option. Security Test Simlock Test 4 What Can We Do If IMEI Is Damaged? A.Simple And Easy Way To Repair Is If U Don't Have Backup. Calculate Bb5 Ask 2 Rpl And Write It. B.Free Way Is Downgrade Phone Then Check. If IMEI And Sp Area Still Damage Update Back And Use Ask 2 Rpl. 5 What If We Have Sp Area Damaged? A. Simple And Easy Way Is If U Have Backup Of Pm 308(Eeprom In Hex 134) Restore It With Write Pm. Remove Phone Insert Battery And Plug Again And Test Phone. B. If U Don't Have Backup Just Use Bb5 Ask 2 Rpl To Repair It. 6 What If I Have Backup Rpl And Not Have Pm Backup? A. Backup Rpl Is For Certificate To Repair Or Restore. So In This You Can Restore IMEI Of Phone But U Can't Restore Sp Area.F.E Configkey –FFFFFFFFFFFFF & PROVIDER - unknown 7 What If I Have Backup Pm And Don't Have Rpl? A. You Can Restore Or Repair Sp Area But U Can't Restore Or Repair Phone IMEI (Certificate) With Only Pm You Need Rpl Backup Or CALCULATED RPL ONLY WAY. 8 Can I Restore Rpl With Usb Cable? A. No You Can't Write Rpl (Certificate) Via Usb Because Its Need Active Flash Mode. 9 What I Do After Rpl Write Still Contact Retailer? A.Most Phone Need To Rewrite Pm Field [1] And [309] B.Most Phone Can Repair With Downgrade And Write Rpl Then Pm To See If Same Then Update Back Then See If Same Use Ask 2 Rpl.. 10 How To Get This Pm Section? A.Read Any Working Phone Pm 1 To 512.Save To Pc.Open It To Notepad And Remove Field - [308] From It Save Again...Now U Can Us It. |
v3 after flash starts and freez | dereje | Motorola P2k | 4 | 02-19-2008 18:57 |
N73 After Flashing | UNIQUEM | Universalbox | 4 | 10-23-2007 12:49 |
n73 after flashing.. too high contrast | ryumahon | Infinity-Box | 4 | 10-13-2007 07:20 |
n73 after flash dead | mobile20 | Nokia Base Band 5 ( BB-5 ) | 7 | 06-18-2007 13:32 |
