06-02-2008, 09:29 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 45
Member: 143156 Status: Offline Thanks Meter: 95 | N73 All Keys Are Not Working Vol&cam& ONLY POWER SWITCH ITS WORK keypad ic already changed 3 TIMES ANY OTHER SOLUTION ???? |
The Following 2 Users Say Thank You to gsm4sp For This Useful Post: |
06-04-2008, 16:31 | #4 (permalink) |
No Life Poster Join Date: Jun 2006 Location: sangam music Punjab India Age: 38
Member: 296651 Status: Offline Sonork: 100.1581376 Thanks Meter: 386 | remove volume key and cam key nd reply |
The Following 2 Users Say Thank You to sonumobilewala For This Useful Post: |
09-17-2008, 20:30 | #11 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 405361 Status: Offline Thanks Meter: 13 | bro same problem in my n73 all key pad is not working set is water damage i cleaned the pcb and change the keypad flex and key pad i.c volume & camera switch pls tell me where is omap ic pls see the diagram of omap i.c |
The Following 2 Users Say Thank You to shammysaini For This Useful Post: |
10-02-2008, 14:45 | #12 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Hwk is the BEST NOKIA TOOL
Member: 735523 Status: Offline Sonork: 100.1591830 Thanks Meter: 262 | Just Change Your Key-Pad IC AND AND AND Just Put Your Mobile Back In Box Without Battery, For 3 or 4 Days.... Then After Check it Its Work 100%CHECED in MANY Pcs.... |
The Following 2 Users Say Thank You to azez.sd For This Useful Post: |
02-24-2010, 18:52 | #14 (permalink) |
Freak Poster Join Date: Jan 2010 Location: INDIA-KL
Member: 1207179 Status: Offline Thanks Meter: 119 | check all keys care fully................. If any one pressed then all key not work |
The Following User Says Thank You to shameerphasan78 For This Useful Post: |
N73 All Keys Are Not Working Vol&cam | gsm4sp | Nokia Hardware & Hardware Repair | 6 | 10-07-2008 13:08 |
6085 All Keys Are Not Working | bdaia2005 | Nokia Hardware & Hardware Repair | 5 | 10-03-2008 06:39 |
5200 all keys are not working... | makkah mobile | Nokia Hardware & Hardware Repair | 12 | 10-03-2007 18:19 |
A&C 60 the comfirm key and the strolling keys are not working | tdnetwork | Siemens Hardware Repair Area | 1 | 12-13-2006 10:51 |
