N73 backlight problem hi, i have one N73 with no baclight. the phone is working fine otherwise but there is no light in display. i have changed the light ic but still same. any suggestions please. w.b.r matrix123 |
change LCD if problem is still same then check LCD curcuit best of luck & Best Regards GSMCrazy1 |
Is there any solution for jumper to solve N73 backlight problem ? |
N73 back light solution 1 Attachment(s) Hi my brother try this i hope your problem will be solve plz reply your anwer. best regards Gsm Stroong:) |
Somebody Help for my slow N73m.. Somebody Help for my slow N73m...:(:( My Problem is: ~ slow to open SMS ~ slow to other files and menu ~ my Multimedia key does't work.. you have to turn it off then on again to function, then after an hour it does't work again...:mad::mad: Please help....:(:(:( Reply or e-mail at this add. [email protected] please............................................ .... |
Help me with my slow N73m How about my important files (contacts,applications,messages and settings)? :confused: does it erase all my files saved on my cellphone?:confused: do i need to back-up all my files? how?:confused: how about my memory card?:confused: thanks for the help...:) |
change LCD if problem is still same then check LCD curcuit.............................. |
i dont undersatnd the grafik either. I have got the same problem wth my n73, no backlight (keyboard and display) could you please explain what you mean with the attached grafik? |
thanks to all............................................... ..... |
I'm not sure if i understand right, so i ask you again. I dont understand the point with the "yellow crossed component" next to the Led drive ic. Three of the ends are still in yellow, and one point is marked in red and connected to the other side of the mainboard on a special ponit. The yellow massage in the picture says "this yellow track not connect change led coil". What do you mean by that? Is it right to connect the red marked point on the coil with the ponit on the mainbaords backside? I'm very sorry for all the questions, but i'm glad that i have found such good help here! I'll tell all my friends about this forum. ;) |
