10-28-2008, 14:21 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: @crackp0d Age: 36
Member: 571377 Status: Offline Sonork: 100.1608017 Thanks Meter: 136 | n73 battery low any solution plzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz |
The Following 2 Users Say Thank You to crackp0d For This Useful Post: |
10-28-2008, 14:46 | #2 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Portugal Age: 48
Member: 318116 Status: Offline Thanks Meter: 16 | Charge your battery only solucion dude, but iff stil say low battery by a new 1 not software problem. |
The Following User Says Thank You to Badboysd For This Useful Post: |
10-28-2008, 19:11 | #4 (permalink) |
Insane Poster Join Date: Oct 2007 Location: kuwait
Member: 610630 Status: Offline Thanks Meter: 37 | Change Betty IC solved problem 100% this is tested solusation , "best of luck" DON'T FORGET CLICK THANKS |
The Following 13 Users Say Thank You to Diamond02 For This Useful Post: |
10-28-2008, 20:32 | #5 (permalink) |
No Life Poster Join Date: Jan 2007 Location: agrabad,ctg,Bangladesh Age: 41
Member: 426688 Status: Offline Sonork: 100.1596204 Thanks Meter: 524 | bro, check your set battery connector short or not i think it may be short, if short you have to change pa post your result |
The Following 2 Users Say Thank You to jimm07ct For This Useful Post: |
10-29-2008, 07:59 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | n73 battery low Quote:
post reply | |
The Following 5 Users Say Thank You to shuaib_kashish For This Useful Post: |
10-29-2008, 09:07 | #10 (permalink) |
Member: 610630 Status: Offline Thanks Meter: 37 | near the RAP3g this is betty ic & also check , if coming PA hit first change PA if no change betty ic. BEST OFF LUCK" DON'T FORGET CLICK THANKES BUTTON" |
The Following User Says Thank You to Diamond02 For This Useful Post: |
01-11-2009, 08:28 | #15 (permalink) |
Crazy Poster Join Date: Jul 2007
Member: 542100 Status: Offline Sonork: http://cranktime.com/ Thanks Meter: 10 | salam to all Can any 1 tell me i got N73 with battery low problem n the problem is its charging ic is not availble in the market can any 1 tell me is this charging ic (BETTY) is is excataly the same with some other models like N70 etc plzzzz let me knw if any 1 can help me . |
The Following 2 Users Say Thank You to ecstatichustler For This Useful Post: |
NOKIA 1110/1112/1600 Battery low SolutionNOKIA 1110/1112/1600 Battery low Solution | gsm junction | Nokia Hardware & Hardware Repair | 3 | 05-06-2013 13:02 |
Nokia N73 battery life is too low | bhcrow | Nokia Hardware & Hardware Repair | 12 | 07-07-2010 09:59 |
n73 call time battery low | SUSHMA | Nokia Hardware & Hardware Repair | 4 | 01-09-2010 14:18 |
N73 show low battery | .RAM | Nokia Hardware & Hardware Repair | 4 | 10-19-2009 21:45 |
Nokia N73 Battery Low Pls Help | nandu_586 | Nokia Hardware & Hardware Repair | 5 | 05-09-2009 16:28 |
