n73 blue screen after flash i flash with same product code file but set go in blue display only befor flash working file only not charging problem hear is flash log Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35354602276098_BA CK.rpl). APE Data : SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0] ASIC MODE ID: 00 PUBLIC ID: 05E9ECCCD175480A89A31E6B3164FAE7B4626160 ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000 ROM ID: 1DFD66132C872FD4 CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B21 PUBLIC ID: 24A000114E514E5075706D3646BB8B7FFFA8A997 ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 Storage0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: FLASH,NAND, asic:APE Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0 Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC Processing MCU file: N73_4.0839.42.2.1_western_C00_PRD_cc.fpsx [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 48.99 MB Supported Ids: 0103192101003000, 010C192101003000 Supported Ids: 17100708 Partitioning ...OK Erase size: 91.38 MB CMT FLASH,NOR area [00080000-00731951] CMT FLASH,NOR area [00000000-0005FFFF] CMT FLASH,NOR area [001E0000-001FFFFF] CMT FLASH,NOR area [00880000-00FEFFFF] erased in 41.125 s Prog.status for Asic CMT ... NOR: OK NAND: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 5E8D0D50 [Rap Certificate 26 v1] sent CMT UPDAPP block sent CMT ADL block sent CMT DSP0 block sent CMT MCUSW block sent APE KEYS block sent APE X-LOADER block sent APE PRIMAPP block sent APE SOS+LOADER block sent APE SOS*UPDAPP block sent APE SOS+UZIP block sent APE PAPUBKEYS: 5E8D0D50 [Ape Certificate 26 v1] sent APE PASUBTOC block sent APE ADL block sent APE SOS+XZIP block sent APE SOS*CORE block sent APE SOS+ROFS block sent APE SOS+ROFX block sent Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 2 min 36.898 s Processing PPM file: N73_rofx_4.0839.42.2.1_PRD.V08 [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 14.70 MB Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000 Supported Ids: 17100700, 17100701, 17100702, 17100708 Partitioning ...OK Erase size: 21 MB erased in 0.284 s Prog.status for Asic APE ... NOR: OK NAND: OK Flash programming ... APE SOS+ROFX block sent Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 56.325 s Processing CNT file: N73_userarea_4.0839.42.2.1.U02 [BB5,BB5 ALGORITHM,BB5,OMAP1710 UNISTORE-II-1.2.1 ALG] size: 7.38 MB Supported Ids: 0000000000000000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000 Supported Ids: 17100708 Erase size: 46.50 MB erased in 0.627 s Prog.status for Asic APE ... NOR: OK NAND: OK Flash programming ... Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 22.647 s Total time for flashing process(boot+erase+write) was 4 min 45.623 s Phone type: RM-133 (Nokia N73) SW version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia. Imei plain: 35354602276098-2 Product code: 0539295 Battery voltage: 4681 mV, current: 50 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353546022760982 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
try bro but result same any other |
just DOWGRADE to 4.0726.2.0.1 with option "downgrade" checked. I guess is not hardware. |
try with this ver flesh ok after flash write rpl ok on computer all softwer done ok but with battery only blank scren |
