04-06-2009, 17:35 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | N73 Camera KEY not working Any suggestion ? PS: problem started first by Autofocus funcion on the Key not working. |
The Following User Says Thank You to yurais For This Useful Post: |
04-06-2009, 17:57 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Bro...........1ast u soldaring camera key......2nly u change this key....ruesult post here......... |
The Following User Says Thank You to mahbubalfa For This Useful Post: |
05-24-2009, 08:07 | #5 (permalink) |
Member: 226172 Status: Offline Thanks Meter: 946 | The camera only works if I use it with the Timer, the buttin doesnt work at all, I checked the button and it is not shorted and it works when I press it, but the phone doesnt interpret the operation it is like if it were disconnected from PCB, I desoldered and resoldered the button again. Any suggestion ? |
06-10-2009, 20:21 | #7 (permalink) |
Insane Poster Join Date: May 2008 Location: nepal
Member: 771642 Status: Offline Sonork: aanshu55 Thanks Meter: 28 | just do it hello bro just do it. it is tested by me and it is 1000% working just click here and post ur result |
The Following 4 Users Say Thank You to aanshu55 For This Useful Post: |
07-26-2010, 20:20 | #9 (permalink) |
Freak Poster Join Date: Dec 2007 Location: bangladesh, chittagong
Member: 648453 Status: Offline Thanks Meter: 82 | after resold N73 camera switch not track ,phone key 1 and 3 not work ,if press 1 displyed 5 and when press 3key it show 7 also if i press camera switch when try to capture a picture, it goes to normal screen from camera shoot screen, but picture is capture and store in phone or memory. plz help what about my keypad problems. i changed key board panel.not solved. |
07-29-2010, 12:51 | #11 (permalink) |
Member: 648453 Status: Offline Thanks Meter: 82 | The camera only works if I use it with the Timer, the buttin doesnt work at all, I checked the button and it is not shorted and it works when I press it, but the phone doesnt interpret the operation it is like if it were disconnected from PCB, I desoldered and resoldered the button again. Any suggestion ?[/QUOTE] i changed switch also make jumper like below post, when i canect jumper to switch then key pad not work i,e if press 1 key it show 5 key on displey. whithout camera switch conect all keypad work normally.plz help to solved camera switch not work. |
08-06-2010, 20:24 | #12 (permalink) |
Member: 771642 Status: Offline Sonork: aanshu55 Thanks Meter: 28 | hey bro, now no need to worry here is ur solution 100000% and very easy too. just try it http://www.4shared.com/photo/zKLUrfj...ch_jumper.html |
11-10-2011, 05:13 | #14 (permalink) | |
Freak Poster Join Date: Aug 2008
Member: 834998 Status: Offline Thanks Meter: 17 | Quote:
link is not work please check it | |
11-10-2011, 05:27 | #15 (permalink) |
Crazy Poster Join Date: May 2010 Location: Moldova Chisinau Age: 52
Member: 1306475 Status: Offline Sonork: 12345 Thanks Meter: 52 | |
The Following User Says Thank You to AlexeyGSM For This Useful Post: |
plis help me...6275 volume key n camera key not working | xuleo | Nokia Hardware & Hardware Repair | 8 | 08-05-2012 13:06 |
N73 volume key not work | kirta | Nokia Hardware & Hardware Repair | 4 | 10-25-2010 22:50 |
Nokia N73 camera key not work solution | mahbubalfa | Nokia Hardware & Hardware Repair | 1 | 11-12-2009 17:13 |
Nokia 7610 Menu & Camera Key not working | Saleemsmj | Nokia Hardware & Hardware Repair | 1 | 10-15-2009 10:37 |
k750i Camera key Not working | broken_rules | Sony Ericsson Hardware Repair | 1 | 09-19-2008 10:04 |
