12-02-2008, 12:15 | #2 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Bangladesh Age: 41
Member: 648647 Status: Offline Sonork: 100.1603328 Thanks Meter: 967 | Quote:
By Shantobhai at 2008-12-02 | |
The Following 10 Users Say Thank You to Shantobhai For This Useful Post: |
05-24-2009, 08:12 | #3 (permalink) |
No Life Poster Join Date: Jan 2006
Member: 226172 Status: Offline Thanks Meter: 946 | The camera only works if I use it with the Timer, the buttin doesnt work at all, I checked the button and it is not shorted and it works when I press it, but the phone doesnt interpret the operation it is like if it were disconnected from PCB, I desoldered and resoldered the button again. Any suggestion ? |
03-28-2010, 07:44 | #5 (permalink) | |
Freak Poster Join Date: Dec 2006
Member: 408989 Status: Offline Thanks Meter: 21 | Quote:
Try to solve using the upper given solution. Actually this solution can be found in N73 schematic, this is just a summarized circuit way provided by a kind person that easy for us to make jumpers. My problem was found from the 25th leg of UI board connector which is the 'blue line' as shown in the picture. Check the circuits between the UI board connector and camera switch which mean just follow the picture shown, again. If all the camera switch circuits are normal then try keypad IC - the Z4400. Normally these two steps do solved most of N73 sets, for my cases. | |
n90 camera blank problam ???....... | bhavinjilka | Nokia Hardware & Hardware Repair | 1 | 10-07-2010 17:39 |
n73 auto keypad and camera work problam solution | vinay_sharma | Nokia Hardware & Hardware Repair | 3 | 11-26-2009 19:12 |
nokia n73 camera botton + front camera | yessine | Nokia Hardware & Hardware Repair | 4 | 08-07-2009 19:03 |
N73 camera swice problam | mahabubtel | Nokia Hardware & Hardware Repair | 7 | 06-07-2009 15:43 |
nokia 5700 camera restart problam | Hariom123 | Nokia Hardware & Hardware Repair | 1 | 11-06-2008 10:15 |
