Old 12-03-2009, 13:44   #1 (permalink)
Member: 277937
Thanks Meter: 48
n73 contact the retailer!!!
pls help sir for n73 contact the retailor.i try to flash with latest version but nothing done
The Following User Says Thank You to danishshah For This Useful Post:
Old 12-03-2009, 13:53   #2 (permalink)
fawad85's Avatar
Member: 301242
Thanks Meter: 201
pls post complete log here bro...
Old 12-03-2009, 16:59   #3 (permalink)
Member: 965890
Thanks Meter: 33
flash with files or low Cleaner
rehot ic combo......
Old 12-03-2009, 17:03   #4 (permalink)
Member: 1024839
Sonork: 100.1592057
Thanks Meter: 64
its a software problem not hardware problem so post in that section which tool u got and for better openion post log thnx
Old 12-04-2009, 00:02   #5 (permalink)
chohansahib's Avatar
Member: 719944
Thanks Meter: 2,117
hi dear,
bro repair sl2 ur problam will solve........
The Following User Says Thank You to chohansahib For This Useful Post:
Old 12-04-2009, 07:31   #6 (permalink)
Member: 277937
Thanks Meter: 48
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Backing up SIMLOCK data...
Setting local mode...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\352916027681767_CRT_backu p_2214312.pm
Done!
Backup LCK OK!
Reading simlock data...
LOCK STATUS:
CONFIG KEY: FFFFFFFFFFFFFFFF
PROVIDER KEY: FFFFFFFFFFFFFFFF
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: CLOSED -> Lock Data: 00101F
Reading imei...
Reading codes data...
Found codes data...
Resetting phone...
Waiting for phone...
Reading soft info...
Writing codes data...
Read SP data error! or Phone not supported
ii try with latest version.but nothing unlock.what shoud i do
Old 12-04-2009, 08:20   #7 (permalink)
Member: 742615
Thanks Meter: 58
First Try to Repair Sl zone and Try Unlock
LOCK STATUS:
Block 1:
if its no Luck then
write good pm PM file
if Results are the same !!!
then
the Last solution is for me is
to make RPL Backup
open it in Noteped
if its Like that then
[CERT_PROG_DATA_OUT_CMT]
NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303533393239350000000000
NPC_DATA_2=0000000000000000000000003051E095742D1C4 75A270100646F7242000000001110011443F86A50
NPC_DATA_3=4C410DB8380CA57C55CE68F15E8D0D504A0902E 261268C14FCD8A2C9093523BCC120BE3119E5B870
NPC_DATA_4=46189B73F63117BECC1CC5E8000000000000000 000000000000000000200000047534D0000000000
NPC_DATA_5=3385360471661408FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000
NPC_DATA_6=31DEB16E1D00000000000000000000000000000 000000000000000000000000050AE275955D34DE8
NPC_DATA_7=7E792D3697F5FCDADB58C249997D2198A2EA8B6 A0EAE5AB35DC093A340A40F6AE6CB5493FFE8C913
NPC_DATA_8=1CDB90ACC5E5E4E3E4F17F991D08BCD1030BC70 A7A752A625F99001959A36569E33E98C9B5859C4F
NPC_DATA_9=A418623E6DC1110D699F082807992147B93E009 13B01E6CDE7A0431BE20F6BBF51A029218E3F26AD
NPC_DATA_10=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
NPC_DATA_11=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
NPC_DATA_12=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Copy Just that area from ok N73 must b unlocked
from its RPL to open it in Noteped too.
VARIANT_DATA_1=357043A5020041500100000030353339323 935430033E093DC71CE448E005600D826990000000000
VARIANT_DATA_2=08000000220000000000000000000000AB9 68C43BFFF7AF7276138E0D251449807EBE517BD6A92CA
VARIANT_DATA_3=025FC6132B207237945BC457C122271FCD7 A00EB2119FEAF7A8FCBED4D2C7BCA903DCF8308ED1403
VARIANT_DATA_4=3E2C060B117A0A8F0DE44E1BC878E1152FB 4646F10CE90BF72F7FB95922B3C8FDC261F1C502E1E20
VARIANT_DATA_5=7EB9CCE7541D6B6ACCD98FBC7217F210776 F0366FB887423FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
and open Damge RPL and paste it and save as in ur Hard drive and then write it
I n s h a l l a h will ok
Old 12-04-2009, 09:54   #8 (permalink)
Member: 277937
Thanks Meter: 48
which mean by sl zone.and how i can do this brother
Old 12-04-2009, 11:58   #9 (permalink)
Member: 277937
Thanks Meter: 48
pls help me sl2 ? and how i solved ths?
Old 12-04-2009, 12:00   #10 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
use Mx-key or Zulea unlocker
Old 12-04-2009, 12:38   #11 (permalink)
Member: 1157462
Sonork: mr.mohit_sam@rediffmai.
Thanks Meter: 3
bro help me I have 5130 showing CONTACT SERVICES
The Following User Says Thank You to ajay.vijay For This Useful Post:
Old 12-04-2009, 13:35   #12 (permalink)
RAHMAN007's Avatar
Member: 915625
Thanks Meter: 47
frist check simlock and security , if security fail write pm with sx4 otherwise u need RPL.
Old 12-04-2009, 14:15   #13 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
Use mt box for repair both of n73 & 5130 if 5130 has corrupted sl so purchase and write rpl file
Asghar Hussain
The Following User Says Thank You to mobilecitycbk For This Useful Post:
Old 12-04-2009, 14:30   #14 (permalink)
Cheater -Don't Deal with him-
Member: 265129
Thanks Meter: 281
1st Check sl Data and IMEI . If Cropted Then u need RPL . If its OK u need Fllowing Steps.
Bro Use MK- Key And Read full PM and Then Load Readed Full PM and Clink on PM Auth. After Complate PM Auth then Write readed Full PM . Your Problome Solve.
BRB.
.::F@iza/\/::.
Old 12-04-2009, 14:37   #15 (permalink)
Don_R's Avatar
Member: 256801
Thanks Meter: 49
LOCK STATUS:
Try lock/Repair option with ub
N73 Contact the retailer ? here logs. .:MobileLife:. Nokia Hardware & Hardware Repair 2 12-31-2009 17:38
N73 contact the retailer..... doktort Cyclonebox 7 07-25-2009 16:24
n73 contact the retailer.... foolish23 Nokia Base Band 5 ( BB-5 ) 5 03-29-2008 13:57
N73 Contact the retailer afzalubaid MT-BOX 3 10-02-2007 12:53
n73 contact the retailer problem!!!! Byte MT-BOX 6 09-28-2007 13:52
Page generated in 0.22258 seconds with 9 queries
