N73 joystick select key not work I change many joyctick but select key not work plz any solution |
If the center key is not working. Check the joystick 4 mark like 1 on it it should be facing up if its facing down the center key dosent work...... |
he is right man change direction of joystick |
YES U R RIGHT change direction 100% WARKING....... I HV SAME PROBLEM ... BUT I SOLVED THIS WAY.. GOOD LUCK...:) TESTED RAVI SOOD!! |
Change the joystick direction, I had similar problem & twas solved |
