Old 07-08-2009, 06:31   #1 (permalink)
Registered User
AS_ADNAN440's Avatar
Member: 1026865
Thanks Meter: 36
N73 joystick select key not work
I change many joyctick
but select key not work
plz any solution
Old 07-08-2009, 06:41   #2 (permalink)
vipimg's Avatar
Member: 446199
Thanks Meter: 40
If the center key is not working.
Check the joystick 4 mark like 1 on it it should be facing up
if its facing down the center key dosent work......
Old 07-08-2009, 06:54   #3 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
have try other keyboard ribben????
or chk it::::http://www.usaupload.net/d/t0euatphqz5
Old 07-08-2009, 08:15   #4 (permalink)
Member: 598454
Thanks Meter: 274
he is right man change direction of joystick
Old 07-08-2009, 08:58   #5 (permalink)
^^^RAVI SOOD^^^'s Avatar
Member: 903492
Sonork: 1590666
Thanks Meter: 570
YES U R RIGHT change direction 100% WARKING.......
I HV SAME PROBLEM ... BUT I SOLVED THIS WAY.. GOOD LUCK...
TESTED
RAVI SOOD!!
Old 07-08-2009, 09:11   #6 (permalink)
Member: 903492
Sonork: 1590666
Thanks Meter: 570
try this way......
Old 07-08-2009, 09:32   #7 (permalink)
Crazy Poster
Member: 921979
Thanks Meter: 9
Change the joystick direction, I had similar problem & twas solved
Old 07-08-2009, 14:07   #8 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
try this pic....
n73 joystick select key solution syl phone Nokia Hardware & Hardware Repair 12 09-02-2010 17:48
Nokia N73 music edition keys not working after changing the debranding code using NSS pistachio9 Nokia Hardware & Hardware Repair 1 08-29-2009 15:30
n73 nokia voluem key not working up down help shani72 Nokia Hardware & Hardware Repair 1 06-17-2009 16:44
N73 joystick all side not work its blocked gsm4sp Nokia Hardware & Hardware Repair 6 09-12-2008 15:41
7610 all keys working fine but joystick right side not working shani72 Nokia Hardware & Hardware Repair 8 07-22-2008 08:36
Page generated in 0.26203 seconds with 8 queries
