Old 11-02-2008, 18:35   #1 (permalink)
Member: 653369
Thanks Meter: 10
N73 key problem
hi. i have an one nokia n73 ,all key work good but when peress 2 aply 7. plz help me
Old 11-02-2008, 19:34   #2 (permalink)
Member: 529487
Sonork: nennoo
Thanks Meter: 42
is ur fone joye stick moving good around 4 ways than change key pad ic. if joy stick not moving good around 4 ways than open crystal and short jumper 1+1, 3+3
Old 11-02-2008, 19:35   #3 (permalink)
Member: 856796
Thanks Meter: 40
sure your unit was dropped,,try the unit first without back cover,if keypad works ,,then put a piece of sponge tape under the battery connector between the back cover,but not too thick or else ringger will loose contact,,then make a big big smile coz your unit is now good
Old 11-02-2008, 20:04   #4 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
Brother try this solution.......................
Enjoy
Old 11-02-2008, 20:05   #5 (permalink)
CPUKILLER's Avatar
Member: 76257
Thanks Meter: 77
so u mean there is a dry connection in omap-cpukiller
Old 11-02-2008, 20:15   #6 (permalink)
Member: 856796
Thanks Meter: 40
not dry connection,open contact or cold solder,,,most likely board deformed,,
Old 11-13-2008, 16:53   #7 (permalink)
CPUKILLER's Avatar
Member: 76257
Thanks Meter: 77
well in basic electronics cold connection or dry connection mean the same ,but thanks for confiming my opinion based on my own experiance and i surely respect your experiance too-regards-cpukiller
Old 11-13-2008, 17:23   #8 (permalink)
sphameed's Avatar
Member: 641058
Sonork: 100.1589325
Thanks Meter: 140
change keypad ic prob solved try that
sp
n73 keys problem smartengg Nokia Hardware & Hardware Repair 12 02-09-2011 13:18
n73 up volume key problem khm050 Nokia Hardware & Hardware Repair 3 09-12-2009 03:17
N73 key 2 problem karim deshne Nokia Hardware & Hardware Repair 1 11-08-2008 18:09
n73 keys not working ok problem after flashing shama_00 SpiderMan 5 06-10-2008 19:08
N73 keypad problem - some keys not working wojtas7650 Nokia Hardware & Hardware Repair 1 05-16-2008 17:13
Page generated in 0.18308 seconds with 10 queries
