05-21-2010, 17:33 | #18 (permalink) |
Junior Member Join Date: Oct 2009 Location: india Age: 35
Member: 1141889 Status: Offline Thanks Meter: 1 | n73 keypad solution 10000000000000%%%%%%%%%%%%%%%%%%%%%%%%%%%% hello bro plz change key pad ic 1000000000%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% working Last edited by shahan2u; 05-21-2010 at 17:40. |
06-06-2010, 21:17 | #22 (permalink) |
Freak Poster Join Date: Nov 2008 Location: kolkata, india
Member: 898155 Status: Offline Thanks Meter: 4 | i think you are not good enough to solder or resolder if you can do that perfectly first remove all the switches including camera cleand the desolder areas and check for short circuit if not ok check key pad board if not solved change the 25 pin ic near key pad connector ok finished |
08-26-2010, 04:17 | #23 (permalink) |
Crazy Poster Join Date: Jul 2009
Member: 1070488 Status: Offline Thanks Meter: 1 | hi dear i have the keypad problem with nokia 6680. it happened after the repairman replaced the data cable connector pins .... and now key "4" and Cancel/NO [red one] is not working... how u solved it ? i am badly in need of any help... plz help me....also the keypad ic was changed thrice but still not working... hope u help me... thanks |
C902 Keypad is not Working Properly | SrviRuS | Sony Ericsson Hardware Repair | 1 | 05-19-2011 20:38 |
C902 Keypad is not Working Properly | SrviRuS | Sony Ericsson | 0 | 03-24-2009 06:39 |
6820 front keypad is not working | Bismillah_mob | Nokia Hardware & Hardware Repair | 5 | 10-15-2008 18:52 |
n73 Keypad led not working | raknahs | Nokia Hardware & Hardware Repair | 1 | 09-21-2008 18:14 |
samsung E370 keypad is not working | mcell | Samsung Hardware Repair | 2 | 09-06-2007 15:29 |
