06-24-2008, 16:51 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: TUNISIA Age: 38
Member: 68330 Status: Offline Thanks Meter: 49 | n73 keypad problem !!!!!!!!!!!!! i have n73 keypad problem -if i push 1 it go to gallery -if i push call key it go to msg -if i push 3 it show 7 its really crazy .......i change keypad ic , flex keypad and i remove up and down keys but still the same what is the solution so !!!!!!!!!!!!!!!!! can be flash ???? thanks in advance |
The Following User Says Thank You to decoder5000 For This Useful Post: |
06-24-2008, 17:12 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Roumania
Member: 461923 Status: Offline Thanks Meter: 2,020 | Quote:
The Following 2 Users Say Thank You to stefani For This Useful Post: |
06-24-2008, 17:17 | #3 (permalink) |
No Life Poster Join Date: Sep 2007 Location: chattisgarh,India
Member: 578941 Status: Offline Thanks Meter: 108 | brother its key pad ics problem. First try to clean it if got no success then just change it ur problem will be 100% Solved |
The Following 2 Users Say Thank You to shok9992000@yah For This Useful Post: |
06-24-2008, 20:09 | #4 (permalink) | |
Insane Poster Join Date: May 2008 Location: doha Age: 39
Member: 775684 Status: Offline Sonork: [email protected] Thanks Meter: 9 | n 73 Quote:
The Following 4 Users Say Thank You to sarassaras For This Useful Post: |
09-18-2008, 06:38 | #5 (permalink) |
No Life Poster Join Date: Mar 2005 Location: INDIA
Member: 130050 Status: Offline Thanks Meter: 83 | Just Change Your Key-Pad IC AND AND AND Just Put Your Mobile Back In Box Without Battery, For 3 or 4 Days.... Then After Check it Its Work 100%CHECED in MANY Pcs.... |
The Following 2 Users Say Thank You to Devashish Mobile For This Useful Post: |
09-18-2008, 06:42 | #6 (permalink) |
Freak Poster Join Date: Sep 2006 Location: punjab
Member: 357914 Status: Offline Thanks Meter: 71 | every time show this error or other means when u change external keyborad when problem same or change and when u change keypad ic then problem same or change or when u remove volume keys then what happen write detail, |
The Following 2 Users Say Thank You to amardeepsahi For This Useful Post: |
09-19-2008, 04:33 | #7 (permalink) |
Junior Member Join Date: Dec 2007 Location: BISHA,K.S.A
Member: 651494 Status: Offline Thanks Meter: 34 | crazy n73 i have too this problem???????????? bro...i have also this problem ...& i have changed all of inner keypad key pad ic at last new cpu but also this prob remains >>>>> no any solution >>>>> now now i have thinking to trogh the crazy 73 to helllllllllllllllllllllllllll>>>>> |
The Following User Says Thank You to thameem For This Useful Post: |
09-19-2008, 06:33 | #8 (permalink) |
Freak Poster Join Date: Feb 2006 Location: ALGERIA (oran city) Age: 46
Member: 227959 Status: Offline Sonork: 100.1589050 Thanks Meter: 254 | n73 ic keypad hi yes it's true the ic keypad Z4400 is related with key up,down and capture key(dual action) remove this 3 keys and post reply good luck |
The Following 6 Users Say Thank You to omega-telecom For This Useful Post: |
10-02-2008, 14:45 | #9 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Hwk is the BEST NOKIA TOOL
Member: 735523 Status: Offline Sonork: 100.1591830 Thanks Meter: 262 | Just Change Your Key-Pad IC AND AND AND Just Put Your Mobile Back In Box Without Battery, For 3 or 4 Days.... Then After Check it Its Work 100%CHECED in MANY Pcs.... |
The Following 2 Users Say Thank You to azez.sd For This Useful Post: |
06-04-2009, 15:10 | #12 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | |
The Following 7 Users Say Thank You to mahbubalfa For This Useful Post: |
06-04-2009, 16:15 | #13 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: U A E
Member: 364745 Status: Offline Thanks Meter: 719 | Quote:
these case not problem keypad ic cabel etc........! some thing like short small black coler cap near camera swiche i have attached the photo just remove and solved your ! 100% best regards IKRAM BUTT | |
The Following 15 Users Say Thank You to ..::Mr_Fone::.. For This Useful Post: |
need help.n73 keypad problem | nic5691 | Nokia Hardware & Hardware Repair | 13 | 08-30-2010 17:48 |
nokia n73 keypad problem | nomi | Nokia Hardware & Hardware Repair | 5 | 10-20-2008 09:14 |
N73 KeyPad Problem...................help | lahoot | Nokia Hardware & Hardware Repair | 7 | 09-16-2008 22:18 |
N73 keypad problem | Fonetec | Nokia Hardware & Hardware Repair | 4 | 08-20-2008 11:06 |
N73 keypad problem - some keys not working | wojtas7650 | Nokia Hardware & Hardware Repair | 1 | 05-16-2008 17:13 |
