Old 09-04-2007, 14:32   #1 (permalink)
Member: 306530
Thanks Meter: 16
N73 Signal Full But Cannot Call
Deal All Master,
I Just Traded In A Nokia N73, After Using About 3 Days, It Start To Show Problem .....
1. Signal Full, But Cannot Make Call ( In & Out )
2. Sometime When I On Then Phone, It Doesn't Show Signal At All But Sometime Signal Full(with 3g) But Only Can Make 1 To 2 Calls, Then Connection Errors...
Is The Problem Serious For N73 ? How To Solve This Problem ?
Thanks In Advance..
Old 09-04-2007, 14:50   #2 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
try 2 change P A i hope it will b ok.......................
..::Mr Fone::..
Old 09-04-2007, 14:53   #3 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
change pf that is the solution....................
Old 09-08-2007, 03:36   #4 (permalink)
Crazy Poster
Member: 253378
frist softwere for the phone
Old 09-09-2007, 06:01   #5 (permalink)
That'sme's Avatar
Member: 228871
Thanks Meter: 43
Originally Posted by VEX-CELL View Post
Deal All Master,
Thanks In Advance..
Flash the phone if not solved then reheat/change the PA.
Old 09-09-2007, 06:03   #6 (permalink)
Mourad120's Avatar
Member: 155016
Thanks Meter: 130
Deal All Master,
Thanks In Advance..
Check Antenna Pads for possible on-Board bad connections ...
Old 09-10-2007, 03:04   #7 (permalink)
Member: 306530
Thanks Meter: 16
hi all, changed PA few days ago, n it works until now nvr show the problem ....
Old 09-10-2007, 03:05   #8 (permalink)
Member: 306530
Thanks Meter: 16
thanks for the helpp.... thanks a lot
Old 09-24-2007, 10:23   #9 (permalink)
Crazy Poster
Member: 253378
hi be shure that your phone sending the id form sam card to the network you use
Old 09-24-2007, 10:25   #10 (permalink)
Crazy Poster
Member: 253378
if your phone sending id to network you have problem with antswich insede the phone or the pa ic
D900i Network..Signal Full But No Calling.. HICHEM TIGS Samsung Hardware Repair 6 05-22-2011 05:30
After repair imei of nokia 2630 , signal have full but cannot make call? svchost Universalbox 1 03-17-2010 11:01
Signal Full but when called failed d.boim Nokia CDMA 5 07-08-2009 04:41
D900i Network..Signal Full But No Calling.. LoveLess UST Pro II 1 08-24-2008 16:25
C45 signal full but can make a call gama_cell99 x1x to x45/x50 1 04-26-2005 18:13
Page generated in 0.33604 seconds with 9 queries
