03-28-2009, 13:32 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Bareilly(U.P) Age: 50
Member: 405715 Status: Offline Thanks Meter: 271 | hi bro. if you have tried with many type of softwares now you should repair with hardware. resold power ic. if same,check sim reader if same,reball/ change power ic. if same,format manually if same,then reflash with latest firmware. try and post reply |
03-28-2009, 15:12 | #8 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: UNITED ARAB EMIRATES Age: 41
Member: 760274 Status: Offline Thanks Meter: 146 | Quote:
If no water inside try this way:- ------------------------------------- mannual format your mobile using (*+3+call+power) then still your problem... Write flash with latest flash file. If yes water inside try this way:- -------------------------------------- check or resold sim tray. Then still final solution rehot or change avilma (power)ic. Then post result..... | |
The Following User Says Thank You to NIMESHFONOTLY For This Useful Post: |
Nokia N73 Sim card Problem | mazeegar101 | Nokia Hardware & Hardware Repair | 4 | 09-03-2010 14:25 |
china n73 when insert sim problems | mccm | Chinese Models & Cloned Phones | 23 | 03-17-2009 20:18 |
n73 rm133 problem SIM card no valid | nafg | J.A.F. Plus | 5 | 02-08-2008 00:02 |
n73 2nd sim problem even after format ffs | sorinm | Infinity-Box | 3 | 02-02-2008 20:32 |
