07-24-2008, 00:24 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: iraq
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | n73 turn off during select the ring tone... i did flash the phone with last ver ME ... but same result... Any solution plz.. Tc |
07-26-2008, 23:44 | #4 (permalink) |
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | i flash the phone on 3 boxes,, Ufs, jaf, mt...same result ... no problem with soft... all log is normal... and the phone rest only during you select the Ring tone... Tc |
07-27-2008, 05:05 | #6 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: 1911 .45 (gubat sa syudad)
Member: 586346 Status: Offline Thanks Meter: 113 | Quote:
try the following: type *#7370# (wait the phone will reset) after the reset go to setting... restore factory setting after this restor factory setting... turn off the phone remove batt for 10 sec then power on and test.... it should be working by now... if not then try this: try to replace one every other test the buzzer... if still not working? try to replace your sound i.c. if still not....then its a big problem with big ic's check you schematic diagram read carefully hope this guide your testing brother... | |
The Following User Says Thank You to miguel_john1975 For This Useful Post: |
Alcatel BE4 Turn off during call | 43e08 | Alcatel TCL Hardware Repair | 6 | 05-01-2008 05:25 |
K510i All functions turned off during the connection | kamransohail786 | Sony Ericsson | 0 | 04-23-2007 15:31 |
nokia 6630 can,t select the ringing tone | EDY.PM | Nokia Base Band 5 ( BB-5 ) | 7 | 10-30-2005 16:56 |
8210 turns off during call: THE REAL SOLUTION! | johny3310 | Nokia Hardware & Hardware Repair | 7 | 05-05-2003 21:26 |
BE4 after unlock turns off during a call | pascal77 | Alcatel & TCL Old Models | 6 | 01-17-2002 01:23 |
