N73 white display i have n73 white display but every thing is working fine i have changed the display but same problem help plz |
i have allready tried it and all other jumpers but still the same and phone is working and making calls normally but white display thanx 4 ur replay |
http://forum.gsmhosting.com/vbb/showthread.php?t=724501 |
n73 display not coming Quote:
i change display conector and display also i chack all track ok of conector byt white display phone is fully function only display not coming i try this jumper but problem not solved |
1-check & change lcd connector on board 2-rehot omap 3-rebal omap 4-change omap 100% solved |
just change ur disply ic... If not work then fault coming to cpu... So..change disply ic ...next cpu.. hope it will done...@@ |
my dear friend can u tell me where is display ic in n73 friend please think for post otherwise not posting plese don't give any advise if u don't know so please mind it for next posting patel telecom |
hi brother where is the display ic im not found in n73 display ic this is rong post |
i have the same problam http://forum.gsmhosting.com/vbb/show...ght=73+display |
1-check & change lcd connector on board 2-rehot omap 3-rebal omap 4-change omap 100% solved As baner2221 the best solution . |
and what is you give us solution first chack and read carefully what is u sharing and what is u posting if u don't know so dond post any fack post we have display related problem and u give us guideance for botting of phone and give us make jumper please can u tel me for not coming in phone's display what take efact your this jumper explain me dear onse again i tell u if u don't no what is solution than don't posting never post fack post:o patel telecom |
