05-24-2009, 10:38 | #1 (permalink) |
Freak Poster Join Date: Mar 2009
Member: 993362 Status: Offline Thanks Meter: 18 | n76 blinking display continous. need help dear sir, i have a n76 problem display continous blinking i try change lcd also change flex but no luck..... i also change the coil & display both ic but still same problem, pls help what i do the unit is clean and im first open thiss.... plsssssssss help me....... |
05-28-2009, 11:42 | #7 (permalink) |
Insane Poster Join Date: May 2008 Location: nepal
Member: 771642 Status: Offline Sonork: aanshu55 Thanks Meter: 28 | this problem can be solved only if u change flex cable with new one if not ok change other one if not ok change one more. if not ok change upper board to check. this problem can occure with lcd ic flex cable and upper board only and often flex cable problem. |
n76 blinking display continous.. need help | onewkhaye | Nokia Hardware & Hardware Repair | 8 | 06-23-2011 23:02 |
E710 Strange Display Problem ! Need Help | goanga | Samsung Hardware Repair | 8 | 10-18-2008 19:02 |
N70 Display Fault.........Need Help | sharaz191 | Nokia Hardware & Hardware Repair | 8 | 08-05-2007 19:35 |
3100 display problem ??? need help | thechatfriend | Nokia Hardware & Hardware Repair | 3 | 03-25-2007 19:41 |
3310 display badly need help | trafix | Nokia Hardware & Hardware Repair | 13 | 05-20-2002 17:39 |
