N8 very slow and memory mass in use Hi members i received nokia n8 with this problem: is very slow and when select memory mass no show information if i open memory mass says: memory un use -flash 2 times in normal mode and in usb dead mode but the result is the same - replace the clock B2200 and the result is the same - reflow the clock B1400 and the result is the same. Somebody was fixed this problem or know how solve this? very thanks |
This point that just mass memory IC is not working - try to check / measure Vmem2 and VIO_eMMC - mostly N3201 and / or N3252 are the problematic. If not work - resolder / change Samsung big eMMC memory IC. |
I think that there are lines not connected then review the plan or comparative measure success |
thanks |
have you try to flash emmc flash memory firstly before doing risky things like remove and make jumper????? this problem can happen when bad EMMC sector and you can fix it using software way. good luck |
