09-02-2012, 02:28 | #1 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 240043 Status: Offline Thanks Meter: 78 | N8 very slow and memory mass in use -flash 2 times in normal mode and in usb dead mode but the result is the same - replace the clock B2200 and the result is the same - reflow the clock B1400 and the result is the same. Somebody was fixed this problem or know how solve this? very thanks |
09-02-2012, 07:31 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | This point that just mass memory IC is not working - try to check / measure Vmem2 and VIO_eMMC - mostly N3201 and / or N3252 are the problematic. If not work - resolder / change Samsung big eMMC memory IC. |
The Following User Says Thank You to debeliamark For This Useful Post: |
09-11-2012, 23:45 | #6 (permalink) |
No Life Poster Join Date: Feb 2009 Location: Algeria-Cne Age: 47
Member: 973866 Status: Offline Sonork: 1603443 Thanks Meter: 297 | have you try to flash emmc flash memory firstly before doing risky things like remove and make jumper????? this problem can happen when bad EMMC sector and you can fix it using software way. good luck |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
