Old 12-14-2011, 00:34   #1 (permalink)
Member: 619511
Thanks Meter: 53
n9 show there is a problem with your sim
i have n9 it show me there is aproblem with your sim, it show ths massege there is no sim card in the phone any solution
thx
Old 12-15-2011, 17:51   #2 (permalink)
Member: 36010
Thanks Meter: 42
something wrong most probably is your cmtmcusw. Try flash again using flasher with the latest firmware and if flashing fail please post the log file. Or you can go to setting and check see if the info of your phone got appear example like imei etc.
Old 12-17-2011, 19:16   #3 (permalink)
Member: 619511
Thanks Meter: 53
thx for reply but i try to update it it fall i chack the imei did not show
Old 12-18-2011, 14:38   #4 (permalink)
bablu333's Avatar
Member: 1495471
Sonork: 1603910:abubablu
Thanks Meter: 1,582
  • QUOTE=ntek;7980676]i have n9 it show me there is aproblem with your sim, it show ths massege there is no sim card in the phone any solution
thx[/QUOTE]
  • here ur solution see
http://forum.gsmhosting.com/vbb/f148...-here-1329558/
The Following User Says Thank You to bablu333 For This Useful Post:
Old 12-19-2011, 12:14   #5 (permalink)
Member: 619511
Thanks Meter: 53
the solution of this problem is not there
thx
Old 12-19-2011, 14:29   #6 (permalink)
bablu333's Avatar
Member: 1495471
Thanks Meter: 1,582
Old 12-19-2011, 15:53   #7 (permalink)
Member: 619511
Thanks Meter: 53
it not insert sim the phone show it show there is a problem with your sim and if u chach imei it will show
thx
Old 01-01-2012, 06:37   #8 (permalink)
Member: 36010
Thanks Meter: 42
disassemble the touch screen from the n9 and see if the switch use to detect the n9 were broken. you can easily see the switch when u insert your sim tray into it, the sim tray will contact the switch and push the spring into it and this detect your sim, if the switch is broken than u need to replace it
Old 01-01-2012, 06:42   #9 (permalink)
Member: 36010
Thanks Meter: 42
wait for awhile. let do it slowly
carefully answer all of my question.
1)When you press *#06# did the imei show up?
2)When you go to the setting and see the about your device, did all of the data were shown correctly to you?
3)Did you flash 100% successfully a not?
Old 01-01-2012, 10:17   #10 (permalink)
Member: 619511
Thanks Meter: 53
1- i chack the imei is not show
2-i go to about product only imei is not show
3-i update it
but still with all this the problem it there
thx
Old 02-23-2012, 15:51   #11 (permalink)
Member: 1725548
@ntek, have you got solved the problem? how? because I have the same.. we are the only 2 people in the world with this problem, doesn't shows imei and at startup says "there's a problem with your sim".. with or without any sim inserted..
Old 02-25-2012, 22:47   #12 (permalink)
Member: 36010
Thanks Meter: 42
if imei doesn't show mean flashing fail. post the log and flash using winflasher.
Old 02-27-2012, 08:12   #13 (permalink)
Member: 1725548
It's not a flash question, because i haven't flashed the phone. The problem came out in the morning, at the startup of the phone; when i turned off it the previous noght, it goes normally. Now i've sent the phone to the nokia care, hoping that they know how to re-animate my device..
Old 07-03-2012, 03:24   #14 (permalink)
Member: 409378
I have same problem with my phone. Sometimes but it shows sim normally.
Imei and certs is all OK. So i think it's hardware problem, Now i'm going to dissamble it...
Old 10-05-2012, 14:17   #15 (permalink)
Member: 194907
Thanks Meter: 114
ı same problem my phone N9 insert sim siım swich is damaged how to jumper sim swich please add jpeg repair advantage thank you
Netmonitor with FBus???? ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-1999 17:04
Page generated in 0.23385 seconds with 10 queries
