Old 09-19-2008, 12:05   #1 (permalink)
Member: 566051
Thanks Meter: 105
n91 key pad
n 91 all key pad not working only set on with power buton and set complet on but any buton not work .........Plz give me solution.Thanks in advance
Old 09-19-2008, 12:17   #2 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
100% working solu.
try this its 100% working to my mobile
The Following 3 Users Say Thank You to omkarvitekar For This Useful Post:
Old 09-19-2008, 13:17   #3 (permalink)
Member: 566051
Thanks Meter: 105
Thanks for post 3 picture. But sir my fault is all buton not work....................befor 20 minut suddenly set run properly...................now stil...............I think shorting in key pad section but where I dont know...............Any idea plz
Old 09-19-2008, 15:26   #4 (permalink)
Member: 639286
Thanks Meter: 27
Just change keypad ic..
Old 09-20-2008, 08:33   #5 (permalink)
Member: 71502
Sonork: 100.1650667
Thanks Meter: 587
try it
my problem is so many time keypad working & suddnly keypad malfaction some keys are working & other not working
i heat all keypad ic, keypad is working few minitus
i try this jumper
all keys are working the problem is sloved
Old 09-20-2008, 09:50   #6 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
IF NOT SOLVED BY ALL THATE PHOTO CHANG IT 1000%
TESTED BY ME
THISH IS MIC IC BUT WHEN MIC ISC SHORT AFTER FEW MINITS ALL CPU LINE TOO SHOORT SO CHANG IT ANDGIVE REPLAY
BR.DYNET
Old 09-20-2008, 12:56   #7 (permalink)
Member: 200653
Thanks Meter: 719
Just jampar keypad ic ???
Old 09-27-2008, 08:16   #8 (permalink)
Member: 800139
Sonork: papuia
Thanks Meter: 30
how to jumper volume button n91
Old 09-27-2008, 08:26   #9 (permalink)
vinay_sharma's Avatar
Member: 309398
Sonork: 100.1590052
Thanks Meter: 5,455
try this bro
http:///vbb/showth...t=vinay_sharma
Old 09-27-2008, 08:47   #10 (permalink)
Rizwan ch08's Avatar
Member: 637860
Sonork: 100.1605309
Thanks Meter: 996
thanks sir good job ......................
Old 09-27-2008, 09:24   #11 (permalink)
Member: 800139
Sonork: papuia
Thanks Meter: 30
keapad was working n91 volume button not work any solution
w550i,the 2,8,# not working.. changed 3 key pad ic,, key pad noww what to do??? broken_rules Sony Ericsson Hardware Repair 2 03-20-2009 15:44
Help For Nokia N91 Key Pad Ic omkarvitekar Hardware Repair Item Wanted 4 09-13-2008 04:42
n91 key pad problem totalmanish Nokia Hardware & Hardware Repair 0 12-25-2007 11:36
key pad N91 majid2000 Nokia Hardware & Hardware Repair 0 01-05-2007 09:02
n91 key pad hang up after 1 min totalmanish Nokia Base Band 5 ( BB-5 ) 3 12-09-2006 13:12
Page generated in 0.18616 seconds with 10 queries
